Home > Technical (L405) > FBH Remote
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
Ha ha, you spotted the low fuel.. it is not normally like that but at the moment it is in the dealers having baffles fitted inside the fuel tank to stop the fuel sloshing around and I had to run it near empty for them to do it. Land Rover are paying for the work. 2016 AB SDV8 Barolo black
Post #674303 26th Sep 2023 10:52am
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
I try to avoid getting below 1/4 tank if possible, it just makes me feel better looking at a full tank First time FFRR owner
Post #674307 26th Sep 2023 11:22am
Arch Stanton
OK team, I now have the newer version of the remote control for the FBH, I need to try and find the correct fuse to pull.
I'd like the option to use the Webasto app to remote start it, I have mailed them and it appears I was trying to use the QR code on the heater but I need to use the QR code on the TCON2 bluetooth module that looks like the picture. Does anyone have an idea where it will be located?
Post #674558 29th Sep 2023 9:14pm
Phoenix
The earlier one was behind the OS 'D' pillar trim, so possibly check there first. The fuse should be fuse 1 on the fuse box behind the OSR side trim.
Post #674560 29th Sep 2023 9:34pm
Arch Stanton
cheers phoenix, I may get chance on sunday to have a look at this, ive just found a YouTube video with someone programming a fob pulling fuse 27 in the passenger side glove box fuses First time FFRR owner
Post #674562 29th Sep 2023 10:39pm
Phoenix
The wiring diagram shows fuse 1 in the fusebox behind the OSR boot trim panel...
You should be able to get to the electrical connector on the receiver so it may be easier to just pull that & reconnect rather than playing fusebox bingo.
Post #674565 30th Sep 2023 5:59am
Maher2023
United Kingdom 2018 Range Rover Autobiography SDV8 Fuji White
I received the remote I purchased from phoenix. Managed to pair by removing the plug from behind D pillar see photo…
Post #674635 1st Oct 2023 10:21am
Arch Stanton
is that in the section near the auxiliary battery or did you have to take off the pillar trim? I'm rather heavy handed when removing those plastic clips and things. Its lashing it down today so not going to get chance til next weekend to look at mine First time FFRR owner
Post #674643 1st Oct 2023 12:10pm
Maher2023
Hi Arch,
No you can take off just the full panel that covers auxiliary battery/fuse box etc…..and then you can look up the D pillar and you can see the receiver. No need to remove D pillar trim.
When it comes to removing connector 3 wires, you need to press the Blue tab and then pull the connector. See attached photo and circled tab.
Post #674646 1st Oct 2023 1:03pm
Arch Stanton
you're a star, thank you. I'm hoping for a window in the rain, that should only take ten minutes First time FFRR owner
Post #674647 1st Oct 2023 1:07pm
Kot
Watching with interest Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #674706 1st Oct 2023 7:06pm
