![]() | Home > Technical (L405) > FBH Remote |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 500 ![]() ![]() ![]() |
I try to avoid getting below 1/4 tank if possible, it just makes me feel better looking at a full tank First time FFRR owner |
OK team, I now have the newer version of the remote control for the FBH, I need to try and find the correct fuse to pull.
The earlier one was behind the OS 'D' pillar trim, so possibly check there first. The fuse should be fuse 1 on the fuse box behind the OSR side trim. |
cheers phoenix, I may get chance on sunday to have a look at this, ive just found a YouTube video with someone programming a fob pulling fuse 27 in the passenger side glove box fuses First time FFRR owner |
The wiring diagram shows fuse 1 in the fusebox behind the OSR boot trim panel...
Maher2023 Member Since: 20 Sep 2023 Location: Leicestershire Posts: 59 ![]() ![]() ![]() |
I received the remote I purchased from phoenix. Managed to pair by removing the plug from behind D pillar see photo…
is that in the section near the auxiliary battery or did you have to take off the pillar trim? I'm rather heavy handed when removing those plastic clips and things. Its lashing it down today so not going to get chance til next weekend to look at mine First time FFRR owner |
Hi Arch,
you're a star, thank you. I'm hoping for a window in the rain, that should only take ten minutes First time FFRR owner |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1260 ![]() ![]() |
Watching with interest |
