Home > Technical (L322) > Suspension comfort change after being on 4 post lift |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7793 |
Unless the rubber bushes moved into a "better” position…. I know they shouldn’t but….
11th Sep 2023 2:23pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3067 |
You’ll have stretched the shock to its full length and moved the oil around inside it when it was jacked.
11th Sep 2023 3:35pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3194 |
I speculated on some redistribution of the oil or release of trapped air in the shocks? Maybe I'll put it extended height mode if it starts to get crashy again. 2012 TDV8 Vogue (L322) |
11th Sep 2023 3:50pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Did you notice the change in both front and rear or perhaps just the rear?
11th Sep 2023 9:13pm |
Reckon it was all the shocks. 2012 TDV8 Vogue (L322) |
12th Sep 2023 6:47am |
Thanks. MW might do well to try putting his L405 on a hoist to see if that improves its ride.
12th Sep 2023 7:28am |
My shocks are original and have 163k miles on them. They work with regards to controlling suspension oscillation but likley past their best with regards to other qualities. 2012 TDV8 Vogue (L322) |
12th Sep 2023 8:12am |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 |
Mine does the same thing - even going to off road height and back down again sometimes gives a temporary ride improvement. It is just that though - temporary. Usually back to normal within a few miles. I haven't been able to figure it out either. Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw
13th Sep 2023 8:44am |
