Home > Maintenance & Mods (L322) > ARB link nut - problem
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
I’ve just tried to fit an Optimal anti roll bar link (supplied by Advanced Factors).
There’s either something wrong with the torque I’m using, or the nyloc nut supplied with the link, or something else I’ve done!
I’ve just destroyed the thread on the link and the nut.
Torque I’m using is 100Nm/74lbft (seems high to me), per the workshop manual.
Wish I had used the original LR flanged nut as that might have been stronger.
Any advice would be welcome!
Post #671536 19th Aug 2023 3:55pm
NDT
I’ve checked and 100Nm is appropriate for an M12 thread.
Post #671564 19th Aug 2023 9:38pm
garyRR
Did you lever the anti-roll bar with a crowbar to take the strain off the linkage ball joint thread whilst tightening the nut? 2015 Range Rover Autobiography 4.4 SDV8
Post #671566 19th Aug 2023 9:46pm
NDT
No, but it looked like it was sitting straight to me.
Will take the pressure off next time. Thanks GaryRR.
Post #671573 20th Aug 2023 8:15am
garyRR
This is probably the reason then. The nut will tighten no problem and without stripping the threads once the pressure from the anti-roll bar is released, and once tightened, the load is then distributed across the nut face and the mating surface on the ball joint. 2015 Range Rover Autobiography 4.4 SDV8
Post #671578 20th Aug 2023 10:08am
Pawl
I've often experienced different thread pitches on aftermarket ARB links.
Is it possible the nut didn't match the ARB stud ? Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #671591 20th Aug 2023 12:37pm
NDT
Good call, but this was the nuts that came on the new link.
Post #671691 21st Aug 2023 9:50pm
