![]() | Home > Maintenance & Mods (L322) > ARB link nut - problem |
NDT Member Since: 03 Apr 2018 Location: Bedfordshire Posts: 85 ![]() ![]() ![]() |
I’ve checked and 100Nm is appropriate for an M12 thread. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Did you lever the anti-roll bar with a crowbar to take the strain off the linkage ball joint thread whilst tightening the nut? 2015 Range Rover Autobiography 4.4 SDV8 |
No, but it looked like it was sitting straight to me.
This is probably the reason then. The nut will tighten no problem and without stripping the threads once the pressure from the anti-roll bar is released, and once tightened, the load is then distributed across the nut face and the mating surface on the ball joint. 2015 Range Rover Autobiography 4.4 SDV8 |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 ![]() ![]() ![]() |
I've often experienced different thread pitches on aftermarket ARB links.
Good call, but this was the nuts that came on the new link. |
