Home > Maintenance & Mods (L322) > ARB link nut - problem |
NDT Member Since: 03 Apr 2018 Location: Bedfordshire Posts: 85 |
I’ve checked and 100Nm is appropriate for an M12 thread. |
19th Aug 2023 9:38pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
Did you lever the anti-roll bar with a crowbar to take the strain off the linkage ball joint thread whilst tightening the nut? 2015 Range Rover Autobiography 4.4 SDV8 |
19th Aug 2023 9:46pm |
No, but it looked like it was sitting straight to me.
20th Aug 2023 8:15am |
This is probably the reason then. The nut will tighten no problem and without stripping the threads once the pressure from the anti-roll bar is released, and once tightened, the load is then distributed across the nut face and the mating surface on the ball joint. 2015 Range Rover Autobiography 4.4 SDV8 |
20th Aug 2023 10:08am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 |
I've often experienced different thread pitches on aftermarket ARB links.
20th Aug 2023 12:37pm |
Good call, but this was the nuts that came on the new link. |
21st Aug 2023 9:50pm |
