Home > Technical (L405) > Cabin air temperature sensor
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
I’ve a fault relating to blocked cabin air sensor, or something like that. Where is it please. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #670807 9th Aug 2023 10:35am
mounted behind a grill on the drivers side of the instrument panel, adjacent the steering column. ... - .- -.
Post #670808 9th Aug 2023 10:50am
knwatkins
Pull the trim off, take it out and give it a clean with a little brush. They get clogged with dust and fluff over time. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #670812 9th Aug 2023 11:18am
GrandadRob
Many thanks Stan. The fan wasn’t moving but it is now. 2013 SDV8 4.4 SE Luxor.
Post #670813 9th Aug 2023 11:28am
like Kev says, it gets very clogged and will affect the auto climate control.. ... - .- -.
Post #670820 9th Aug 2023 12:42pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Would anybody be able to point to the area in the workshop manual that details accessing this sensor? I am suspecting that I may well need to replace mine due to this error that I posted yesterday?
B105A-71 State: Permanent
Passenger compartment temperature sensor fan - actuator stuck _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #710932 3rd Feb 2025 3:36pm
all detailed how to in above posts....???? ... - .- -.
Post #710935 3rd Feb 2025 3:49pm
ReggieMac
Sorry, I didn't explain myself properly. I meant so that I could see any diagrams in the WM to be sure of the correct part and that I am looking at the right one. Thumbs Up
When I search the WM I get results for lots and lots of sensors and I cant see the wood for the trees! _______________________________________________
Post #710938 3rd Feb 2025 4:08pm
knwatkins
Here you go...
 Kev
Post #710973 3rd Feb 2025 10:06pm
ReggieMac
Perfect! Thank you very much Thumbs Up _______________________________________________
Post #710974 3rd Feb 2025 10:09pm
ReggieMac
Before I go and spend the best part of £60 for a replacement part could anybody suggest any way that I could test this part now that I have removed it just to confirm it is a failed part and not something electrical with the car? _______________________________________________
Post #711027 4th Feb 2025 3:57pm
its probably gunked up, clean it and make sure the fan spins freely...re-install and see if thats solved your problem. ... - .- -.
Post #711029 4th Feb 2025 4:24pm
ReggieMac
Out of interest should this little fan be spinning all the time when you start the car or are there specific conditions for when it is supposed to be spinning? i.e. do you have to have the aircon on or be over a specific temperature? I have read all of the sections I can in the WM and the one thing I cant find are details of what constitutes normal operational conditions, only fault scenarios. _______________________________________________
Post #711030 4th Feb 2025 4:28pm
ReggieMac
So it turns out that this little fan is supposed to be spinning all the time and, despite a thorough cleaning, I could not get mine to work again so managed to find a brand new genuine replacement for £47 and fitted it today, all sorted and thanks for your help guys. Thumbs Up _______________________________________________
Post #711124 5th Feb 2025 4:32pm
happy days Thumbs Up ... - .- -.
Post #711134 5th Feb 2025 5:23pm
