![]() | Home > Technical (L405) > Cabin air temperature sensor |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35592 ![]() ![]() |
mounted behind a grill on the drivers side of the instrument panel, adjacent the steering column. ... - .- -.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 773 ![]() ![]() ![]() |
Pull the trim off, take it out and give it a clean with a little brush. They get clogged with dust and fluff over time. Kev
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 238 ![]() ![]() ![]() |
Many thanks Stan. The fan wasn’t moving but it is now. 2013 SDV8 4.4 SE Luxor.
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 218 ![]() ![]() ![]() |
Would anybody be able to point to the area in the workshop manual that details accessing this sensor? I am suspecting that I may well need to replace mine due to this error that I posted yesterday?
all detailed how to in above posts....???? ... - .- -.
Sorry, I didn't explain myself properly. I meant so that I could see any diagrams in the WM to be sure of the correct part and that I am looking at the right one. |
Here you go...
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Perfect! Thank you very much |
Before I go and spend the best part of £60 for a replacement part could anybody suggest any way that I could test this part now that I have removed it just to confirm it is a failed part and not something electrical with the car? _______________________________________________
its probably gunked up, clean it and make sure the fan spins freely...re-install and see if thats solved your problem. ... - .- -.
Out of interest should this little fan be spinning all the time when you start the car or are there specific conditions for when it is supposed to be spinning? i.e. do you have to have the aircon on or be over a specific temperature? I have read all of the sections I can in the WM and the one thing I cant find are details of what constitutes normal operational conditions, only fault scenarios. _______________________________________________
So it turns out that this little fan is supposed to be spinning all the time and, despite a thorough cleaning, I could not get mine to work again so managed to find a brand new genuine replacement for £47 and fitted it today, all sorted and thanks for your help guys. |
happy days |
