![]() | Home > Technical (L322) > Front end banging |
Roll bar bushes? Mine were totaly shot but they had not started making any noise. They are bonded to the roll bar so unfortunatley you have to replace the whole thing. 2012 TDV8 Vogue (L322) |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 216 ![]() ![]() ![]() |
Where the control arms torqued up to the correct spec with the wheels on the ground? |
JoshVogue94 Member Since: 18 Aug 2022 Location: RCT Posts: 56 ![]() ![]() ![]() |
Checked them with a bar mate no movement at all |
Yes everything torqued as per service manual |
gedebo Member Since: 08 Jul 2021 Location: Stockholm Posts: 3 ![]() ![]() |
I was looking at a video from overlanding 4WD and he had knocking from the front, first they thought it to be warpt disc's, but that didn't help. Then they realised that to pot's on the front calipers where sized. Put new calipers on and it solved it. So i guess that's what i will check next, since i am chasing the same issue..... |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 394 ![]() ![]() ![]() |
...I've got exactly the same issue... and have changed everything up front like you.
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 195 ![]() ![]() |
I also have a short muffled bang from the NSF when the brakes are applied sharply at low speed, but I haven't had it over bumps. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
You said you had new airbags. Was it just the bags or the whole strut? If just the bags, I would suspect the struts. The dampers will be worn. John
The shocks on mine were very nearly as stiff at 170k miles as the new ones I put on which was a suprise. No oil in the bags either to suggest leaking. 2012 TDV8 Vogue (L322) |
Giffer2018 Member Since: 25 May 2020 Location: West Yorkshire Posts: 60 ![]() ![]() ![]() |
If the struts are Dunlop ones it could be that. My NSF one knocks if I hit a pot hole or rough road, rest of time silence. -----------------------
