Home > Technical (L322) > Front end banging
JoshVogue94
Wales 2011 Range Rover Vogue 4.4 V8 Santorini Black
UPDATE
The knocking still hasn't gone away, the vehicle has now had brand new upper and lower control arms, new drop links, new inner and outer tie rods and alignment still the knocking is there.
I can create the noise when going over bumps or tapping the breaks sharply at low speeds and it happens every time. My next thought is the transfer box has anyone else had these symptoms? Seem to be throwing money at it and not getting any closer.
Post #690437 11th Apr 2024 8:02pm
JayGee
Roll bar bushes? Mine were totaly shot but they had not started making any noise. They are bonded to the roll bar so unfortunatley you have to replace the whole thing. 2012 TDV8 Vogue (L322)
Post #690447 12th Apr 2024 6:02am
PeteT80
Where the control arms torqued up to the correct spec with the wheels on the ground?
Post #690451 12th Apr 2024 6:37am
JoshVogue94
Checked them with a bar mate no movement at all
Post #690455 12th Apr 2024 7:12am
JoshVogue94
Yes everything torqued as per service manual
Post #690456 12th Apr 2024 7:13am
gedebo
Sweden
I was looking at a video from overlanding 4WD and he had knocking from the front, first they thought it to be warpt disc's, but that didn't help. Then they realised that to pot's on the front calipers where sized. Put new calipers on and it solved it. So i guess that's what i will check next, since i am chasing the same issue.....
Post #693840 3rd Jun 2024 12:55pm
Superspoons
...I've got exactly the same issue... and have changed everything up front like you.
It's like the brake disks are loose .... they aren't.
I'm thinking Prop Bearing ? Driving me nuts trying to figure out what it is. I've also had a new drivers side driveshaft but it did it before then. Gavin
Post #693841 3rd Jun 2024 1:41pm
toby1
I also have a short muffled bang from the NSF when the brakes are applied sharply at low speed, but I haven't had it over bumps.
Post #693870 4th Jun 2024 8:59am
Weegie
You said you had new airbags. Was it just the bags or the whole strut? If just the bags, I would suspect the struts. The dampers will be worn. John
GAP iiD BT
Post #693871 4th Jun 2024 9:13am
JayGee
The shocks on mine were very nearly as stiff at 170k miles as the new ones I put on which was a suprise. No oil in the bags either to suggest leaking. 2012 TDV8 Vogue (L322)
Post #693905 5th Jun 2024 7:54am
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
If the struts are Dunlop ones it could be that. My NSF one knocks if I hit a pot hole or rough road, rest of time silence. -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #694361 13th Jun 2024 11:30am
