Home > Maintenance & Mods (L322) > RR ‘02 air suspension is going down after replacing bags
Menno RR vogue 02
Netherlands 2002 Range Rover Vogue 4.4 V8 Epsom Green
Hi all,
I’ve replaced the two air suspension bags on the back because after a few days the car dropped left. Now it stays levelled but is still drops after 1-2 days. Does anybody know what to check next to figure out what is causing it? I hope someone had the same issue and solved it…
Thanks!!
Menno
Post #669455 20th Jul 2023 6:59am
Put it up to off road height, get a spray bottle with soapy water in and spray the airbags and lines back to the valve block... you should see where it leaks, if nothing, move the suspension to normal and access and try again.
If it's quiet you can often hear the leak...
Good luck... Thumbs Up Pete
Post #669458 20th Jul 2023 7:47am
Menno RR vogue 02
Thanks!
I did spray the valveblock already. I can't reach all the lines, but I will listen to it on a quiet sunday morning. Very Happy
The bags are brand new so they won't have a leak I guess.
Post #669459 20th Jul 2023 7:51am
Don't presume anything, new parts can be faulty or the bag seats aren't clean, they tend to get a ridge of road dirt that sets like concrete and can cause a leak... Thumbs Up Pete
Post #669462 20th Jul 2023 7:58am
Menno RR vogue 02
oke well... Good to know I will check them to then! Confused
But it's definitly a leak you rekon?
Post #669464 20th Jul 2023 8:50am
It's usually a leak, and happening after work gives a bit of a clue BUT, if it's sitting and keeps levelling until it drops that may indicate an issue, you can rule that out by pulling the air suspension fuse but I can't remember which one it is, you could just disconnect the battery for a couple of days to see if it drops... Thumbs Up Pete
Post #669470 20th Jul 2023 10:34am
Menno RR vogue 02
That sounds like a good plan Thumbs Up
I'm going to give that a go!
Will get back with the result!
Post #669480 20th Jul 2023 12:43pm
Remove Relay number 4 Thumbs Up on board below rear fuse board.
Post #669491 20th Jul 2023 4:54pm
Gsxr1250dave
What brand did you fit ?
Post #669495 20th Jul 2023 6:11pm
Menno RR vogue 02
Brilliant! Thumbs Up Thumbs Up Thumbs Up
Post #669496 20th Jul 2023 6:11pm
Menno RR vogue 02
I fitted aerosus ones:
https://aerosus.nl/land-rover/range-rover/...zijde.html
Post #669498 20th Jul 2023 6:13pm
Are you certain you pushed the airlines fully into the new bags?
Post #669504 20th Jul 2023 8:02pm
Menno RR vogue 02
Well I thought I did… Confused I pushed until it didn’t go any further but I didn’t used a lot of force. Do you have to use a lot of force?
Post #669505 20th Jul 2023 8:21pm
No you don’t need a lot of force but you should feel a definite stop.
Post #669508 20th Jul 2023 9:05pm
Merchy
For the airlines, I usually depress the collet, push the tube in, ( sometimes it can be a tight fit ) let the collet spring back up ( or pull it up )then try to pull the pipe to see if it is tight, it could also be a little bit of damage to the end of the plastic tube when it was removed that could cause a leak, when I did my fronts, I trimmed a little bit ( About 10mm ) off the ends of the pipes to get a good fit /seal.
That is IF you have push fittings on yours, as opposed to the olive ring and screwed fittings ?
Post #669509 20th Jul 2023 9:08pm
