![]() | Home > Maintenance & Mods (L322) > RR ‘02 air suspension is going down after replacing bags |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8358 ![]() ![]() ![]() |
Put it up to off road height, get a spray bottle with soapy water in and spray the airbags and lines back to the valve block... you should see where it leaks, if nothing, move the suspension to normal and access and try again.
Menno RR vogue 02 Member Since: 20 Jul 2023 Location: Baarn Posts: 9 ![]() ![]() ![]() |
Thanks!
Don't presume anything, new parts can be faulty or the bag seats aren't clean, they tend to get a ridge of road dirt that sets like concrete and can cause a leak... |
oke well... Good to know I will check them to then! |
It's usually a leak, and happening after work gives a bit of a clue BUT, if it's sitting and keeps levelling until it drops that may indicate an issue, you can rule that out by pulling the air suspension fuse but I can't remember which one it is, you could just disconnect the battery for a couple of days to see if it drops... |
That sounds like a good plan |
Remove Relay number 4 |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 928 ![]() ![]() |
What brand did you fit ? |
Brilliant! |
I fitted aerosus ones: https://aerosus.nl/land-rover/range-rover/...zijde.html |
Are you certain you pushed the airlines fully into the new bags? |
Well I thought I did… |
No you don’t need a lot of force but you should feel a definite stop. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
For the airlines, I usually depress the collet, push the tube in, ( sometimes it can be a tight fit ) let the collet spring back up ( or pull it up )then try to pull the pipe to see if it is tight, it could also be a little bit of damage to the end of the plastic tube when it was removed that could cause a leak, when I did my fronts, I trimmed a little bit ( About 10mm ) off the ends of the pipes to get a good fit /seal.
