Home > Maintenance & Mods (L322) > RR ‘02 air suspension is going down after replacing bags |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Put it up to off road height, get a spray bottle with soapy water in and spray the airbags and lines back to the valve block... you should see where it leaks, if nothing, move the suspension to normal and access and try again.
20th Jul 2023 7:47am |
Menno RR vogue 02 Member Since: 20 Jul 2023 Location: Baarn Posts: 9 |
Thanks!
20th Jul 2023 7:51am |
Don't presume anything, new parts can be faulty or the bag seats aren't clean, they tend to get a ridge of road dirt that sets like concrete and can cause a leak... Pete
20th Jul 2023 7:58am |
oke well... Good to know I will check them to then!
20th Jul 2023 8:50am |
It's usually a leak, and happening after work gives a bit of a clue BUT, if it's sitting and keeps levelling until it drops that may indicate an issue, you can rule that out by pulling the air suspension fuse but I can't remember which one it is, you could just disconnect the battery for a couple of days to see if it drops... Pete
20th Jul 2023 10:34am |
That sounds like a good plan
20th Jul 2023 12:43pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Remove Relay number 4 on board below rear fuse board.
20th Jul 2023 4:54pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
What brand did you fit ? |
20th Jul 2023 6:11pm |
Brilliant! |
I fitted aerosus ones: https://aerosus.nl/land-rover/range-rover/...zijde.html |
20th Jul 2023 6:13pm |
Are you certain you pushed the airlines fully into the new bags? |
20th Jul 2023 8:02pm |
Well I thought I did… I pushed until it didn’t go any further but I didn’t used a lot of force. Do you have to use a lot of force? |
20th Jul 2023 8:21pm |
No you don’t need a lot of force but you should feel a definite stop. |
20th Jul 2023 9:05pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
For the airlines, I usually depress the collet, push the tube in, ( sometimes it can be a tight fit ) let the collet spring back up ( or pull it up )then try to pull the pipe to see if it is tight, it could also be a little bit of damage to the end of the plastic tube when it was removed that could cause a leak, when I did my fronts, I trimmed a little bit ( About 10mm ) off the ends of the pipes to get a good fit /seal.
20th Jul 2023 9:08pm |
