Home > Technical (L322) > Air suspension leak |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 311 |
Hi all
30th Jun 2023 8:00am |
I had the car up, at the time it was holding. Feeling around where the pipe is and suddenly I heard the air escaping. That’s why I wondered if there was a valve or something in the wheel arch as I can find where it’s coming from atm.
30th Jun 2023 4:09pm |
When it’s not under the weight of the car, the bag goes solid when the compressor is on. Tym
30th Jun 2023 4:10pm |
… and to add to the confusion, I was in the supermarket car park this evening and she levelled out perfectly. Stayed at ride height all the way home and remains there 3 hours later. Tym
30th Jun 2023 8:55pm |
Update: it’s the bag. Bought a new jack and managed to find a puncture. Temp fix with superglue and gaffer tape until it’s replaced on 20 July. Tym
5th Jul 2023 7:35am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Sorted, well nearly, interested to hear if superglue would fix it, even temporarily, the pressure is pretty high and I would have thought it would get blown straight out....
5th Jul 2023 9:59am |
24 hours and 40 miles later it seems to be holding. I could put my finger over the hole in the bag and stop it leaking so it must have been very small. At full height it didn’t leak, probably due to the pressure it put in itself and sealed the hole? I put tape over to mark the spot, but couldn’t actually see a hole. Smeared CA glue over the area then put some gorilla gaffer tape over the glue and smoothed it out. Not going to risk altering height as I just need it to hold until 20 July when it’s replaced under warranty 😉 Tym
5th Jul 2023 10:40am |
Amazing... Must put some super glue in the glovebox.... Pete
5th Jul 2023 11:20am |
It’s not perfect, just holding. Tym
5th Jul 2023 12:55pm |
Tym
5th Jul 2023 4:00pm |
Hmmm. Not holding! 😞🤣 Tym
6th Jul 2023 7:35am |
