Home > Technical (L322) > Air suspension leak
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Air suspension leak
Hi all
I’ve got a dreaded leak from front near side. Garage suspected the bag so one on order and the warranty’s company has pre approved it. However… I’m not convinced it’s the bag.
A couple of days after it first sank, it lifted again and stayed there. Not it’s sunk again and lifts slowly but not high enough.
I jacked it up to see if I could see/feel a leak. When it’s in the air, and the suspension is ‘normal’ height, the bag is solid - no leak.
When I lower the car again, there’s a hissing sound.
Could the be the valve block? Is that somewhere around in the front near side wheel arch? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #667927 30th Jun 2023 8:00am
Merchy
It could still be the bag, if possible put the car in off road height and investigate further / soapy water spray test etc.
The front valve block on mine ( 2006 ) is under the offside wheel arch liner, in the rear of the wheel well.
Post #667983 30th Jun 2023 3:16pm
tymh
I had the car up, at the time it was holding. Feeling around where the pipe is and suddenly I heard the air escaping. That’s why I wondered if there was a valve or something in the wheel arch as I can find where it’s coming from atm.
On top of this, my 3 tonne trolley jack broke, so waiting in a new on next week that’s got a higher lift. Tym
Post #667990 30th Jun 2023 4:09pm
tymh
When it’s not under the weight of the car, the bag goes solid when the compressor is on. Tym
Post #667991 30th Jun 2023 4:10pm
tymh
… and to add to the confusion, I was in the supermarket car park this evening and she levelled out perfectly. Stayed at ride height all the way home and remains there 3 hours later. Tym
Post #668012 30th Jun 2023 8:55pm
tymh
Update: it’s the bag. Bought a new jack and managed to find a puncture. Temp fix with superglue and gaffer tape until it’s replaced on 20 July. Tym
Post #668370 5th Jul 2023 7:35am
Sorted, well nearly, interested to hear if superglue would fix it, even temporarily, the pressure is pretty high and I would have thought it would get blown straight out....
Did it work at all...?? Pete
Post #668381 5th Jul 2023 9:59am
tymh
24 hours and 40 miles later it seems to be holding. I could put my finger over the hole in the bag and stop it leaking so it must have been very small. At full height it didn’t leak, probably due to the pressure it put in itself and sealed the hole? I put tape over to mark the spot, but couldn’t actually see a hole. Smeared CA glue over the area then put some gorilla gaffer tape over the glue and smoothed it out. Not going to risk altering height as I just need it to hold until 20 July when it’s replaced under warranty 😉 Tym
Post #668396 5th Jul 2023 10:40am
Amazing... Must put some super glue in the glovebox.... Thumbs Up Pete
Post #668404 5th Jul 2023 11:20am
tymh
It’s not perfect, just holding. Tym
Post #668414 5th Jul 2023 12:55pm
tymh
 Tym
Post #668430 5th Jul 2023 4:00pm
tymh
Hmmm. Not holding! 😞🤣 Tym
Post #668474 6th Jul 2023 7:35am
