Home > Maintenance & Mods (L322) > AC clutch question help.
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Found the HVAC in the IID tool menu, says the compressor is OFF.
But I have some cold air coming through and I can hear the engine change when I turn the AC on and off???
Post #668325 4th Jul 2023 3:28pm
philip1972
Anyone?
Just wondered if your IID tools say your compressor in on when the AC is on?
Cheers
Post #668496 6th Jul 2023 1:01pm
garyRR
Yes, mine does say through IID. And with the blower down low with the windows open and engine idling, when I press the A/C button, I can hear the clutch engaging. 2015 Range Rover Autobiography 4.4 SDV8
Post #668521 6th Jul 2023 4:14pm
philip1972
Hmmm, the engine note changes when I press "on", but it always says "off" when looking at IID.
Does that mean the compressor is dead?
Post #668523 6th Jul 2023 4:17pm
garyRR
It may mean that's simply not monitored on your car.
Get someone to turn the a/c button on and off whilst you look down with a torch. You should see the clutch engaging and disengaging or at least a physical sign the engagement of the compressor puts additional load on the belt/engine. 2015 Range Rover Autobiography 4.4 SDV8
Post #668524 6th Jul 2023 4:20pm
philip1972
I can clearly hear the additional load when turning the AC on, no doubt about that.
The evaporator temperature does not fall when monitoring as you would expect and the air while a tad cooler is nowhere near what I think it should be!
I am a bit stumped to be honest.
Post #668525 6th Jul 2023 4:24pm
garyRR
I would get a garage to place a pressure tester on the A/C system. They can confirm if there's a leak, but they can also confirm if there's too much pressure on either the high or low side of the system.
If the latter, then it's likely your PCV and a new compressor is needed.
If the former, then you know there's a leak to find.
If neither, then maybe your condensate pipe as next port of call. 2015 Range Rover Autobiography 4.4 SDV8
Post #668526 6th Jul 2023 4:29pm
JayGee
Most garages these days have an AC machine and will test the system for free and charge if it needs a refill or other work. 2012 TDV8 Vogue (L322)
Post #668527 6th Jul 2023 4:30pm
Weegie
You can test the pressure with the Gap iid. John
GAP iiD BT
Post #668528 6th Jul 2023 4:33pm
philip1972
Pressure on the GAP says something like 16 (cant remember the units Embarassed ).
Post #668533 6th Jul 2023 5:47pm
philip1972
Oh and it was charged on a garage machine that tested for leaks on Tuesday.
Thanks for the help so far, I appreciate it.
If I was in the UK I would take it to a specialist, but there is not many around in France!!
Post #668534 6th Jul 2023 5:48pm
philip1972
As an update (and more help required) I tested it this morning. 25c outside temp.
Evaporator temp 15.7 and pressure 15.3 bar, not cold air.
Recess to 2.5 k and slowly evap temperature came down to 9.7 and pressure up to 20 bar.
Any ideas?
Post #668564 7th Jul 2023 9:02am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
20 bar is way too high pressure for normal operation. Looks like there's possibly an issue on the high side, either expansion valve blocked/freezing or a compressor problem.
Just for comparison, my AC on my 2012 4.4TDV8 works perfectly since I replaced the condenser and regassed it. In similar conditions mine runs at around 10bar, getting up to no more than 13bar when stationary, and evap temperature hovers around 1.5 to 3deg C 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #668566 7th Jul 2023 9:14am
garyRR
I would suggest the Pressure Control Valve on your compressor has failed (common on a lot of cars).
The resolution is vacuum out gas, replace compressor with new, leak test, re-gas. 2015 Range Rover Autobiography 4.4 SDV8
Post #668568 7th Jul 2023 9:22am
philip1972
Thank you. Garage job or DIY?
I can’t find any guides on the internet for the 4.2 anywhere!
Post #668585 7th Jul 2023 12:26pm
