Home > Maintenance & Mods (L322) > AC clutch question help. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 |
Anyone?
6th Jul 2023 1:01pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
Yes, mine does say through IID. And with the blower down low with the windows open and engine idling, when I press the A/C button, I can hear the clutch engaging. 2015 Range Rover Autobiography 4.4 SDV8 |
6th Jul 2023 4:14pm |
Hmmm, the engine note changes when I press "on", but it always says "off" when looking at IID.
6th Jul 2023 4:17pm |
It may mean that's simply not monitored on your car.
6th Jul 2023 4:20pm |
I can clearly hear the additional load when turning the AC on, no doubt about that.
6th Jul 2023 4:24pm |
I would get a garage to place a pressure tester on the A/C system. They can confirm if there's a leak, but they can also confirm if there's too much pressure on either the high or low side of the system.
6th Jul 2023 4:29pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Most garages these days have an AC machine and will test the system for free and charge if it needs a refill or other work. 2012 TDV8 Vogue (L322) |
6th Jul 2023 4:30pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 |
You can test the pressure with the Gap iid. John
6th Jul 2023 4:33pm |
Pressure on the GAP says something like 16 (cant remember the units ). |
6th Jul 2023 5:47pm |
Oh and it was charged on a garage machine that tested for leaks on Tuesday.
6th Jul 2023 5:48pm |
As an update (and more help required) I tested it this morning. 25c outside temp.
7th Jul 2023 9:02am |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
20 bar is way too high pressure for normal operation. Looks like there's possibly an issue on the high side, either expansion valve blocked/freezing or a compressor problem.
7th Jul 2023 9:14am |
I would suggest the Pressure Control Valve on your compressor has failed (common on a lot of cars).
7th Jul 2023 9:22am |
Thank you. Garage job or DIY?
7th Jul 2023 12:26pm |
