![]() | Home > Maintenance & Mods (L322) > AC clutch question help. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
Anyone?
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Yes, mine does say through IID. And with the blower down low with the windows open and engine idling, when I press the A/C button, I can hear the clutch engaging. 2015 Range Rover Autobiography 4.4 SDV8 |
Hmmm, the engine note changes when I press "on", but it always says "off" when looking at IID.
It may mean that's simply not monitored on your car.
I can clearly hear the additional load when turning the AC on, no doubt about that.
I would get a garage to place a pressure tester on the A/C system. They can confirm if there's a leak, but they can also confirm if there's too much pressure on either the high or low side of the system.
Most garages these days have an AC machine and will test the system for free and charge if it needs a refill or other work. 2012 TDV8 Vogue (L322) |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
You can test the pressure with the Gap iid. John
Pressure on the GAP says something like 16 (cant remember the units |
Oh and it was charged on a garage machine that tested for leaks on Tuesday.
As an update (and more help required) I tested it this morning. 25c outside temp.
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
20 bar is way too high pressure for normal operation. Looks like there's possibly an issue on the high side, either expansion valve blocked/freezing or a compressor problem.
I would suggest the Pressure Control Valve on your compressor has failed (common on a lot of cars).
Thank you. Garage job or DIY?
