Home > Technical (L322) > Air con woes and error message.
Anvil
Hi All,
Just had my air con re gassed and it worked for a little while although not at the same freezing level I seem to remember when I had the car at first. I took it back to the local garage, and they checked for leaks, and there don’t appear to be any. There’s still stacks of gas in it. However the compressor is not kicking in as needed. They put it on a code reader and got the following error message in the photo. I think it ends in “or ground”. First of all they don’t know where the sensor is located and understandably didn’t want to get too buried in Land Rover electronics ! They’ve recommended I go to a specialist. I thought I’d try here before going anywhere else! Be really grateful for any ideas. Thanks in advance, Si. FFRR 4.2SC/KTM 990SMT Current and cherished.
Honda Accord 2.4 Vtec touring. (Yeah, I know, think: Kids)
Mitsubishi Pajero Evolution Nut-wagon. and a Buell XB12R
TVR Griffith 5.0 (backed up with Vauxhall Carlton road barge for the weekly shop.)
Honda Integra Type R DC2 Possibly the best drivers car. Ever.
Mitshibishi FTO GPX MIVEC.
Honda CRX Vtec Mk2 -NO, Not the del sol!!!
Volkswagen Scirocco GT
Mini 1275GT
MG Midget (Heavily modified)
I'm going to stop now.....
Post #667792 28th Jun 2023 2:53pm
Anvil
Sorry to bump this folks, but does anyone know where the cabin air con temp sensors are please? Not the ambient one just above the clock, but there must be left and right for the driver/passenger zone control? Really can’t face a trip to London with passengers and no air con!
Thank again in advance,
Mini 1275GT
Post #668160 2nd Jul 2023 6:23pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Si,
Does sound quite similar to my own experience.
I'd suggest the refrigerant control valve as a likely culprit - it's a commonly occurring problem.
Have a look at this thread - https://www.fullfatrr.com/forum/topic43778...ed+air+con
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #668170 2nd Jul 2023 9:55pm
garyRR
The pressure control valve issue is widely known on the 4.4 TDV8 as linked, but not so much your engine.
That said, they are common culprits in any air conditioning system on any car. My symptoms were:
- air con would work well sometimes
- a burst of acceleration over 2,300 RPM fired the air con into life
- lots of idling traffic / slow speed and no air con
Plenty of gas in the system. When Halfords tested it, they confirmed loads on the high side and none on the low side confirming my PCV (the test was free).
I'd also used the GAP tool and the cabin temperature sensors were working fine - so may be something you're able to do. If you're getting a temperature reading from the sensors, then neither are open loop.
You could also have a faulty clutch on the a/c compressor.
You could also have a blocked condensate pipe, although you'd probably expect to see the compressor running.
For me, Halfords vacuumed out the gas for free, I changed the air con compressor for a new one and then got Halfords to recharge for me and all has been well since. 2015 Range Rover Autobiography 4.4 SDV8
Post #668175 2nd Jul 2023 10:21pm
Anvil
Kiss My Carbon Footprint wrote:
Si,
Warwick
Thanks for the response, much appreciated. Think I’d still like to check on the temp sensors though as that’s what the error message is saying. Reading through that thread it looks like Ross at Grenlands sounds a good bet for proper diagnosis too. Not a million miles from me as I’m in Dorset. Still like to know where those damned temp sensors are! Rolling with laughter FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #668195 3rd Jul 2023 9:42am
Anvil
Thanks Gary, much appreciated. It doesn’t seem that my compressor is even spinning up at all so I wonder if it’s a sensor before all of that. Complicated stuff air con! Very Happy FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #668197 3rd Jul 2023 9:44am
garyRR
If you get someone with the proper diagnostics or GAP tool (i have a GAP tool and live in Southampton - would need another member to confirm if the tool can be used to see live values on other cars without unlocking), they'll be able to see the live values for your cabin temperature sensors, evaporator temperature to confirm the system is getting cold enough, and that your compressor clutch is functioning. They may also be able to obtain some more insightful fault code detail. 2015 Range Rover Autobiography 4.4 SDV8
Post #668198 3rd Jul 2023 9:49am
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Can you tell me where in the iid those values are please?
Post #668200 3rd Jul 2023 10:31am
Anvil
thanks Gary, I’ll look into that. I’m a big fan of starting with the cheapest/simplest first, so getting a solid pointed seems the logical way! FFRR 4.2SC/KTM 990SMT Current and cherished.
Mini 1275GT
Post #668212 3rd Jul 2023 1:29pm
