![]() | Home > Technical (L405) > Kwik fit can’t do wheel allignment |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3145 ![]() ![]() ![]() |
You need to put the suspension into tight tolerance mode I believe (or at least on the L322 you do). I wonder if they don’t have diagnostics to do that? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Post deleted. |
TPhipps Member Since: 24 Feb 2023 Location: Cotswolds Posts: 18 ![]() ![]() ![]() |
Try choose one with the hunter alignment system. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
See if you can find another wheel alignment specialist. Steer clear of kwikfit (sorry for the pun). |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
you can find a kwik fit that does the hunter hawkeye alignment online..
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4317 ![]() ![]() ![]() |
I see you’re in West Sussex
www.glenrands.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1584 ![]() ![]() ![]() |
See my post below, the latest Hunter system is called “WinAlign”
Great to see it happening “before your eyes” and no paranoia about the WD40 trick by shady operators… |
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 52 ![]() ![]() |
Mr Tyre did mine, after rear sub-frame swap, did a great job, drives spot on, and central...
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
Hi, you can try
Always ask “How do you put it in Tight Tolerance Mode?”
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 282 ![]() ![]() ![]() |
+1 for GlenRands they did a great job on mine in March this year. TDV8 4.4 2012 |
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 ![]() ![]() |
Back when I had my Sport I used these and they were spot on. So I highly recommend. https://thetyreshop.com/ L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
