Home > Technical (L405) > Kwik fit can’t do wheel allignment
Foster2018
United Kingdom 2018 Range Rover Autobiography SDV8 Carpathian Grey
Hi all my local Kwik fit, usually good for wheel allignments say they can’t do it on my 2018 L405 because they need a special tool which they don’t have? Are they talking Censored ? Or is this a genuine issue?
Rang merityre and they don’t believe anything is needed? But can’t fit me in for a few days?
Any ideas?
Thanks
Tom
Post #667622 26th Jun 2023 4:26pm
dhallworth
You need to put the suspension into tight tolerance mode I believe (or at least on the L322 you do). I wonder if they don’t have diagnostics to do that? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #667630 26th Jun 2023 5:47pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Post deleted.
Post #667634 26th Jun 2023 6:19pm
TPhipps
United Kingdom 2016 Range Rover Vogue SE TDV6 Santorini Black
Try choose one with the hunter alignment system.
Post #667637 26th Jun 2023 6:41pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
See if you can find another wheel alignment specialist. Steer clear of kwikfit (sorry for the pun).
Post #667639 26th Jun 2023 7:03pm
you can find a kwik fit that does the hunter hawkeye alignment online..
they did mine and very well to. ... - .- -.
Post #667641 26th Jun 2023 7:13pm
DrRob
I see you’re in West Sussex
Take it to Glenrands in Passfield. Proper kit, proper knowledge and proper customer service.
Tell them I sent you 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667644 26th Jun 2023 7:36pm
DrRob
www.glenrands.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667645 26th Jun 2023 7:36pm
Gremlin500
See my post below, the latest Hunter system is called “WinAlign”
https://www.fullfatrr.com/forum/topic67178.html
Obvs location is no good for you! Laughing “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #667651 26th Jun 2023 8:28pm
Gremlin500
Great to see it happening “before your eyes” and no paranoia about the WD40 trick by shady operators… Shocked “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #667652 26th Jun 2023 8:30pm
bobsin
2004 Range Rover Vogue Td6 Epsom Green
Mr Tyre did mine, after rear sub-frame swap, did a great job, drives spot on, and central...
Post #667667 27th Jun 2023 1:56am
M11buc
United Kingdom 2019 Range Rover Autobiography SDV8 Santorini Black
Hi, you can try
https://alignmycar.co.uk/
you should be able to find some one with hunter’s equipment here. Maybe worth checking they have equipment to put in tight tolerance mode before booking in.
Hope it helps.
Post #667669 27th Jun 2023 2:20am
DrRob
Always ask “How do you put it in Tight Tolerance Mode?”
If they look at you blank or dismiss it, walk away. Quickly Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667680 27th Jun 2023 7:22am
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
+1 for GlenRands they did a great job on mine in March this year. TDV8 4.4 2012
Post #667820 28th Jun 2023 11:23pm
ilard
Back when I had my Sport I used these and they were spot on. So I highly recommend. https://thetyreshop.com/ L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #668118 1st Jul 2023 9:30pm
