Home > Technical (L322) > Dpf is full in amber |
Craig5 Member Since: 05 May 2023 Location: Liverpool Posts: 42 |
And is it best to get genuine? |
22nd Jun 2023 10:50am |
My soot count is increasing I’ve been told it can be the p040d fault causing it |
22nd Jun 2023 12:10pm |
Is part 22904 temp sensor on exhaust? |
22nd Jun 2023 12:15pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
Yes. It's in the exhaust and a to replace hence why I said take it to a specialist
22nd Jun 2023 12:21pm |
I've heard this can have an impact but I'd be first looking at the 4 plenum intake hoses and the intercooler-throttle body BIG hose for any splits. It needs a pro on it IMHO Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
22nd Jun 2023 12:22pm |
Hi dr rob my only issue is will it get to the garage before it turns red from amber with the soot count increasing |
22nd Jun 2023 12:23pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
The soot count will increase until such time the onboard computer decides it's time to perform a regen.
22nd Jun 2023 12:28pm |
I have taken it on motorway today and amber light is now off |
22nd Jun 2023 12:30pm |
It's working. You can drive yourself nuts with it
22nd Jun 2023 2:32pm |
I’ve noticed when it looks like my car is doing a regen it only seems to drop about 3-4 then stops that seems ok? My soot at moment is 11.5 |
31st Jul 2023 12:52pm |
I’ve just did some logging on my gap tool exhaust temp sensor bank 1 and bank 3 only changed temps with different driving speeds but sensor 2 would read say 285 then split second would got to 100 then back to 285 then say 135 for split second then back to 285 is that normal? do the temp sensors control the regen at all? |
31st Jul 2023 3:52pm |
All connected in terms of feedback etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
31st Jul 2023 4:22pm |
I don’t understand your reply sorry |
31st Jul 2023 4:30pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
the exhaust sensors don't read below 100 so looks like you may have a dodgy sensor or wiring fault. Temp sensors are a crucial part of the regen system and in reply to your earlier post the full regen should drop soot to below 4g 2012 TDV8 Vogue (L322) |
1st Aug 2023 6:56am |
