![]() | Home > Technical (L322) > Dpf is full in amber |
Craig5 Member Since: 05 May 2023 Location: Liverpool Posts: 42 ![]() ![]() |
And is it best to get genuine? |
My soot count is increasing I’ve been told it can be the p040d fault causing it |
Is part 22904 temp sensor on exhaust? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Yes. It's in the exhaust and a |
I've heard this can have an impact but I'd be first looking at the 4 plenum intake hoses and the intercooler-throttle body BIG hose for any splits. It needs a pro on it IMHO ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Hi dr rob my only issue is will it get to the garage before it turns red from amber with the soot count increasing |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
The soot count will increase until such time the onboard computer decides it's time to perform a regen.
I have taken it on motorway today and amber light is now off |
It's working. You can drive yourself nuts with it |
I’ve noticed when it looks like my car is doing a regen it only seems to drop about 3-4 then stops that seems ok? My soot at moment is 11.5 |
I’ve just did some logging on my gap tool exhaust temp sensor bank 1 and bank 3 only changed temps with different driving speeds but sensor 2 would read say 285 then split second would got to 100 then back to 285 then say 135 for split second then back to 285 is that normal? do the temp sensors control the regen at all? |
All connected in terms of feedback etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I don’t understand your reply sorry |
the exhaust sensors don't read below 100 so looks like you may have a dodgy sensor or wiring fault. Temp sensors are a crucial part of the regen system and in reply to your earlier post the full regen should drop soot to below 4g 2012 TDV8 Vogue (L322) |
