Home > Technical (L322) > Dpf is full in amber
Page 2 of 3 <123>
Craig5
And is it best to get genuine?
Post #667297 22nd Jun 2023 10:50am
garyRR
Please stop forcing regens when the car's onboard ECU is managing it appropriately and not throwing any error codes. It's un-necessary and will only cause problems elsewhere.
The car's computer and DPF management system is acting as it should and producing an amber alert prompting you to drive above 50mph for a sustained period for it to do what it needs to do. When my vehicle was used for short trips around the city, the amber alert came up occasionally and all it needed was taking to the motorway for a 20 mile run - quite a nice thing to do on a summer's evening.
The red alert on the driver display is often caused by an intake leak and the DPF is the symptom, not the cause (a danger of using diagnostic kit); even then, this is often long preceded by the red "restricted performance" message on acceleration and produces no need to fiddle with the DPF. The intake leaks are well documented on this forum and easily fixed on the driveway with basic tools. Once those are ruled out, only then should a DPF regen be forced.
The P040D error is unlikely to cause any problems in the medium term.
The faulty sensor is likely to be the one shown below (LR022904), however there are multiple on the exhaust system, so you will need to confirm which one.
 2015 Range Rover Autobiography 4.4 SDV8
Post #667301 22nd Jun 2023 11:41am
Craig5
My soot count is increasing I’ve been told it can be the p040d fault causing it
Post #667302 22nd Jun 2023 12:10pm
Craig5
Is part 22904 temp sensor on exhaust?
Post #667303 22nd Jun 2023 12:15pm
DrRob
Yes. It's in the exhaust and a Censored to replace hence why I said take it to a specialist
https://www.fullfatrr.com/forum/topic50202.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667304 22nd Jun 2023 12:21pm
DrRob
I've heard this can have an impact but I'd be first looking at the 4 plenum intake hoses and the intercooler-throttle body BIG hose for any splits.
It needs a pro on it IMHO Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667305 22nd Jun 2023 12:22pm
Craig5
Hi dr rob my only issue is will it get to the garage before it turns red from amber with the soot count increasing
Post #667306 22nd Jun 2023 12:23pm
garyRR
The soot count will increase until such time the onboard computer decides it's time to perform a regen.
You can continue using the vehicle normally. What you have reported doesn't sound like there's a big issue. To extinguish the amber alert, you need to take it on a run.
When you have a spare few hours, take the various hoses off as in the article Rob linked and have a good inspection as well as squeeze for any splits. This is a good thing to do twice a year anyway. 2015 Range Rover Autobiography 4.4 SDV8
Post #667307 22nd Jun 2023 12:28pm
Craig5
I have taken it on motorway today and amber light is now off
Post #667308 22nd Jun 2023 12:30pm
DrRob
It's working. You can drive yourself nuts with it Rolling with laughter
Check 1) it has no intake leaks and 2) don't use it for too many short journeys. This applies for any car with a DPF. They like long runs.
Enjoy it Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #667310 22nd Jun 2023 2:32pm
Craig5
I’ve noticed when it looks like my car is doing a regen it only seems to drop about 3-4 then stops that seems ok? My soot at moment is 11.5
Post #670154 31st Jul 2023 12:52pm
Craig5
I’ve just did some logging on my gap tool exhaust temp sensor bank 1 and bank 3 only changed temps with different driving speeds but sensor 2 would read say 285 then split second would got to 100 then back to 285 then say 135 for split second then back to 285 is that normal? do the temp sensors control the regen at all?
Post #670162 31st Jul 2023 3:52pm
DrRob
All connected in terms of feedback etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #670170 31st Jul 2023 4:22pm
Craig5
I don’t understand your reply sorry
Post #670172 31st Jul 2023 4:30pm
JayGee
the exhaust sensors don't read below 100 so looks like you may have a dodgy sensor or wiring fault. Temp sensors are a crucial part of the regen system and in reply to your earlier post the full regen should drop soot to below 4g 2012 TDV8 Vogue (L322)
Post #670194 1st Aug 2023 6:56am
Page 2 of 3 <123>
