Home > Technical (L405) > L405 deployable sidestep module location?
andygts
Does anyone know the location of the factory fitted deployable sidestep module? Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #666228 9th Jun 2023 8:33am
Looks like it's in the side panel of the boot
&t=26s
Post #666232 9th Jun 2023 8:52am
andygts
Bow down Thumbs Up
Nows hoping I find some dodgy wiring bewteen that and the passenger step motor Current
Previous
Post #666233 9th Jun 2023 8:59am
Laughing Thumbs Up
Post #666240 9th Jun 2023 10:38am
andygts
No need, the Censored's working today Banging Head Current
Previous
Post #666374 11th Jun 2023 4:49pm
caymanblack
I think a lot of us on here have had problems and the answer seems to be lubrication, lots of it !
Also when I'm not using it much and perhaps just getting it in and out of the garage I turn them off.
Glad its ok . overfinch modified
Post #666375 11th Jun 2023 4:53pm
andygts
Mine isn't a lubrication issue, It works perfectly fine when it works, when it doesn't, it doesn't even attempt to move. When it refuses to move it will sometimes work if you keep pressing unlock, it's a wierd one as the drivers works everytime.
No faults on IID tool, every signal that I can think to check reagarding doors etc are opertional on the IID tool. If it thought there was obsatcle it wouldn't deploy the drivers either I can't find a reason for it not deploy.
1st step was going to be try to deploy it manually using 12v fed into the harness, figured it's cleaner and easier job + it will prove the wiring. Current
Previous
Post #666413 12th Jun 2023 9:36am
Gremlin500
Glad its ok .
This.
Search on here, it’s a very common issue with the DSS’s.
Passenger side usually more affected due to less use. On my MY2017, I have to douse everything in ACF50 a few times a year, (which is messy stuff to have dripping all over your driveway, but seems to work for a good few months), -situation worse in Winter, obvs.
Shame JLR didn’t include a few grease nipple points…… “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #666437 12th Jun 2023 1:09pm
