Home > Maintenance & Mods (L322) > Ramps
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Ramps
I am trying to decide if I need some ramps or not, I am getting fed up of wheeling out a trolley jack and rolling about on he floor to locate it and then line up axle stands.
I have read as many posts as I can find on ramps but I still have questions
So to see what is available I came across the following
1, https://www.diy.com/departments/1-pair-hea...904_BQ.prd
2. https://www.manomano.co.uk/p/2x-car-ramp-h...ck-6752702
3. https://www.fullfatrr.com/forum/topic62679.html?highlight=ramps
A wide range of costs here but I wonder how much lift do I need?
I need them to be useable for any car but our MG might be a problem and may need an extension ramp.
So how much lift do I need for a universal ramp?
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #665988 6th Jun 2023 12:51am
wayneg
I am in Australia but am sure there will be 2nd hand steel ramps on Facebook Market / ebay etc for very little in the UK. I work on several low cars and use 1mt lengths of scaffold planks to make the rise shallow enough. With the Range Rover, it's a doddle, I do put it in low range for more control, gives the hi/low a workout too.
https://www.ebay.co.uk/itm/325680711185?ha...R7KR3--RYg 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #665991 6th Jun 2023 4:43am
Baltic Blue
I am a big fan of using car ramps, but for a slightly different reason.
My drive is not level, but the ramps soon solve that problem, making it easy to level up the car for oil changes etc.
It also gives loads of room to get safely under the car, rear end , or front by reversing up the drive then driving the front wheels up the ramps.
Being plastic they are very light and totally maintenance free, yet still strong enough to safely lift the car.
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #665992 6th Jun 2023 7:01am
JayGee
Make your own. Always found commercially available ramps too narrow. I know it’s stating the obvious but never found ramps particularly useful as you are very limited as to what you can do with them as anything that involves removing wheels is not possible. 2012 TDV8 Vogue (L322)
Post #665994 6th Jun 2023 7:09am
Baltic Blue
The plastic ramps are VERY wide compared to most.
My tyres are 255 55 20 and comfortably sit on the ramps with no overhang.
To remove the wheels is also easy using my “sprinter” bottle Jack stood on suitably high wooden blocks.
Post #665997 6th Jun 2023 7:40am
JMC
I bought some hefty (400x400x300mm) blocks of wood and can raise the vehicle up by 700mm in a few mins. A decent trolley jack helps, of course. Whistle
It only takes me two lifts with the jack - one at the front, on the sump guard, and one on the middle of the tow-bar at the rear. Blocks underneath and hey presto!
 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #665999 6th Jun 2023 7:47am
i have the same type as baltic blue [mike]
they are very solid, light and easily stored.. ... - .- -.
Post #666004 6th Jun 2023 8:27am
Strider
I welded up some ramp extensions, the octy vrs is very low at the front so the attack angle
has to be very shallow and they seem to work ok with fatty. The end height is about 1 foot.
Post #666017 6th Jun 2023 1:45pm
DrRob
Same as Baltic Blue. Heavy duty wide plastic ramps. Superb 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #666030 6th Jun 2023 4:47pm
TJH1985
Or get some budget creep as I did....
Rolling with laughter Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #666031 6th Jun 2023 5:01pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I have thought about those, how ray are they really to move around?
Post #666034 6th Jun 2023 5:03pm
TJH1985
Mine live in the garage with a car on top of them, they are heavy but I can drag them in and out fairly easily I wouldn't say it takes me any longer than dragging out Jacks and axle stands etc. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #666089 7th Jun 2023 10:29am
bigbo
Thanks all, lots of info.
One of my main questions was how much lift do I need?
I am leaning towards building my own with sleeper sized timber, but I will make them wider than 9" like the plastic ramps some of you use.
MG TF 2003
Post #666141 8th Jun 2023 12:46am
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
These are rated at 12ton a pair and works perfectly for what I need
Post #666343 11th Jun 2023 6:36am
garyRR
David
Made from 9x2 C24 timber. Super heavy duty and cheap to make. The timber fits the tyre well, and are just as safe for use on inclines/declines. Plastic and metal are typically only recommended for level ground, due to the torsional forces that result from uneven ground.
If I did it again, I'd reduce the steps by 5cm in length, and add a fifth step (easily added at any point) 2015 Range Rover Autobiography 4.4 SDV8
Post #666475 12th Jun 2023 9:01pm
