![]() | Home > Maintenance & Mods (L322) > Rear Bag Advice |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 ![]() ![]() ![]() |
Gents I am doing the wheel arches so decided to overhaul rear suspension and do hub bushes and arms as well ass wheel bearings and thought I have never replaced the rear bags on the suspension in the 10 years I have owned it. Thinking I might just do them (on well over 200k ) Thoughts? |
My thoughts as well I cant recall anyone having a problem with the rears failing |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
I would think, all the suspension components will show wear after 200k... |
To be fair Craig I replaced all the bushes including subframe at about 120k also the front bags and shocks and rear shocks wheel bearings and arms regularly its just the rear bags which I never replaced they look ok and no leaks but I am a preventative maintenance man as opposed to wait till it breaks so will just replace them |
Dunlop gont have a good reputation as far as air suspension is concerned sir... |
Thanks Craig |
I am guessing Arnott's were original supplier |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3143 ![]() ![]() ![]() |
I put Bilstein from Island 4x4 on mine and have had no issues with them.
Thanks David I think it is because the 3.6 of that era used a different shock and bag and they are too small for the diesel not sure but think that is it |
Epson Green Member Since: 20 Mar 2021 Location: Sutton Coldfield Posts: 113 ![]() ![]() ![]() |
The OE supplier was Delphi who became BWI. Kevin 2012 L322 Westminster 4.4 TDV8 1999 P38A 4.0 SE - Sold |
