Home > Maintenance & Mods (L322) > Bonnet latch
Rambles
Bonnet latch
On the bonnet latch, there is a very small rubber spacer, about 5 mm in length, with a slot in the middle to fit over a hook in the latch.
This has perished on my 2011, resulting in the bonnet now needing to be gently closed with the latch held open - absent the little rubber spacer the latch now wont slide over the lip but needs to be held open.
Any chance these rubber spacers can be obtained separately or do i need to get a new latch ?
Thank you
Post #665400 29th May 2023 3:44pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
a picture is always good so we can see your problem and help in any way we can oggy new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #665485 30th May 2023 3:59pm
