![]() | Home > Maintenance & Mods (L322) > [Mechanical] PCV Hose Replacement |
StevieH Member Since: 05 Feb 2009 Location: Cumbernauld, Lanarkshire Posts: 117 ![]() ![]() ![]() |
Dan very kindly helped me out with some of the hose he used after I struggled to get the specs listed above.
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
dan just checked mine last nite and even though the pipes are intact they seem ever so squishy and pliable do the new pipes feel like that or do i have a split waiting to happen
Did you run your hand down the entire length of both top hoses to make sure thy haven't failed lower down at the back? If they are squishy they need replacing, did you check the third hose at the bottom of the cyclone?
When i had mine done the mech couldn't get a hose on the bottom either, although it was clamped to the cyclone. Upon further investigation there is a 4th hose, I know you really don't want to hear that! It's this one:
Mine was found when I had to have the whole cover replaced (after a mech broke it!) It wasn't attached to the cover near HC4 on the diag' but the hose was all blocked up. Also the tube on the cover (hc4) was bunged up too so the mech just capped it off rather than try and find the remains of this hose and replace it. It drains any excess oil out of the Oil Separator Valve, but with it capped I've not noticed any problems, especially as I've done 20,000 miles with it hanging off and blocked up previously. ![]() |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I had mine in last week getting the PCV hoses replaced, a new droplink, (so much for them being replaced at the last MOT before I bought the car!) and a new thermostat and housing including one of the sensors, (i think!).
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
I found the 4th hose when I was there but didn't realise it was connected to the PCV, it was in okay condition so I wasn't worried about it. I actually assumed it was a vacuum hose or something like that. |
I did this job again on the new car. It's been suffering from high idle and not great mpg as well as the check engine light coming on with P1171 and P1174 codes.
tommac22 Member Since: 10 Nov 2010 Location: devon Posts: 55 ![]() ![]() ![]() |
Dan, where did you purchase the patten parts? do you have part numbers? |
Where the third Hose picture Dan? |
The Third and Fourth hoses were fine Gaz ![]() |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 ![]() ![]() ![]() |
Hi Dan,
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
If you are feeling very flush with dosh then both AliSport and Twisted Performance sell silicone based high performance replacement pipes for most Land Rover cars 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
mario.costasa Member Since: 01 Mar 2011 Location: St Albans Herts Posts: 3 ![]() ![]() ![]() |
Just to check on the parts list required form this tread
You definately don't need 3M of hose.
