![]() | Home > My Range Rover > Roastpenguin's 3.6 |
RoastPenguin Member Since: 11 May 2023 Location: West Midlands Posts: 29 ![]() ![]() |
Hmm, plenty of masking tape and a steady hand then. I'll update when I get around to doing them, review the holts kit for you all.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
That seams very cheap to me… Just make sure they are not cutting corners on quality of parts they are using sir… |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1365 ![]() ![]() |
Cost more in parts, I reckon they have missed a 1 off the front 😂😂😂 |
Nooo thats just labour. I'm supplying parts. Genuine prop from advanced factors over 400 and a genuine zf kit with lifeguard oil, 300 notes 3.6 TDV8 Java Black Last edited by RoastPenguin on 12th Jun 2023 12:40pm. Edited 1 time in total |
See above, there'll be 4 digits in total!😆 3.6 TDV8 Java Black |
Apologies sir… |
Got one of the headlights refurb'd yesterday 👍🏻
After
Not too bad tbf
I used an autoglym kit on a mates last year, better results than this holts kit so out of the 2 id recommend autoglym. I'll see how these go with repeat periodic applications of the sealer then I might try a meguiars kit if they fade again 3.6 TDV8 Java Black |
GKN rear prop and ZF gearbox kit arrived today 😀
Genuine filter kit with proppa oil and mechatronic seals, 300 notes from www.gearboxoils.com , they've got an ebay store and do all sorts of gearbox stuff, not just oils if anyone needs anything! Genuine rear prop from AF was just over £460 delivered 👍🏻forgot to use forum discount if it still applies 🤦🏻♂️ Fitting end of next month, 2 days before I need to tow the caravan 😬😬😬 Jobs for future include thermostat housing, rocker cover leaks, 1 or both heater control valves, rear hub bushes and a part worn pirelli on drivers rear if I can find one...* *(this list is not exhaustive )🤣 3.6 TDV8 Java Black |
Its all gone wrong 😪
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
That's a great shame, you were sorting it all out so well...
Thanks for your kind words, appreciated 🙂 I did feel like it was getting to be a good un...
