Home > Technical (L322) > Steering knock SOLVED! |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
Interesting, I’m going to have a look as I have the same thing, I can feel through the track rod ends, steering rack is secure and the track rod ends are good, really annoying over bumpy ground 2009 (2010 MY) 5.0 Supercharged Autobiography
11th May 2023 5:41am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2487 |
Where exactly is the nut? Mine rattles at 1 end but the inner joints were replaced only a short while ago and no play can be felt with the ball-joint disconnected from the knuckle. |
11th May 2023 8:33am |
David FX Member Since: 12 Dec 2022 Location: california Posts: 2 |
11th May 2023 8:13pm |
Thanks - much appreciated. |
11th May 2023 8:52pm |
MrAwesome1 Member Since: 27 Nov 2024 Location: San Diego Posts: 2 |
Hello, I have the same issue with a new (refurbished) rack/pinion. I went to adjust the tension, the noise eventually goes away but the steering wheel is now super tight. I tried backing it off but the noise comes back. Any advice would be appreciated. Thanks! |
27th Nov 2024 10:26pm |
Did the refurbished rack include the rack-ends? Mine's rattle was due to a very prematurely worn-out inner rack-end balljoint due to dirt ingress from an improperly fitted rack boot. Another steering noise, a loud groan, was caused by a dry ball-joint in a front Delphi brand suspension arm which had only been fitted 1 year earlier. |
28th Nov 2024 12:02am |
Hi thanks for the quick response. I fitted with new ends when I replaced the rack. Its definitely the rack, I had my son move the steering wheel back and forth while I was under the car. |
28th Nov 2024 12:12am |
