Home > Technical (L322) > Lost communication with transmission module HELL |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Still putting my money on the battery... Personally I don't believe in coincidence.
22nd Nov 2024 1:43pm |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 346 |
Thanks Pete i will do mate and hope your wife is doing well, what i dont understand is the battery will start the car no issues, it will start the gear knob will rise i can take hand break off but 5 seconds later all warnings on the dash gear knob goes down and you cand move it, if i put a charger on and try to clear the codes whilst its being charged it wont clear them just says update failed when clearing the codes, im asking around for a new battery to try but im loosing the will with this car now 2012 Range Rover Westminster 4.4 TDV8
22nd Nov 2024 1:49pm |
They can be very tricky sometimes and test you dearly.
22nd Nov 2024 4:57pm |
22nd Nov 2024 4:58pm |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 48 |
Mine did exactly this a while ago. The transmission module is just in front of the brake servo. I checked for continuity on the main feed from the fuses by the battery, through to the trans module and found a bad connection to the relevant fuse in the under bonnet fuse box |
22nd Nov 2024 6:16pm |
Hi Dtech that sounds like my issue, anychance you could take some pitures of the areas i need to look at please mate 2012 Range Rover Westminster 4.4 TDV8
23rd Nov 2024 11:56am |
Sorry I won’t be able to provide pics as I am abroad at the moment. The fuse box under the bonnet is easy to see just to the left of the engine. I would also suggest removing the transmission module connector to check for corrosion etc. from recollection the trans module is just to the left of the wiper motor.[/quote] |
23rd Nov 2024 12:59pm |
pjw888 Member Since: 04 May 2023 Location: Dumfries Posts: 28 |
Hi there, I did send you a om with some suggestions. I wondered if you had progressed and fixed this fault? |
25th Nov 2024 6:24pm |
Thanks for all the replies I’ve been working away so not had chance to take a look. I replaced the battery with a new one unfortunately this did not help, I’m on site again until sat so I’ll check fuses and plugs then 2012 Range Rover Westminster 4.4 TDV8
28th Nov 2024 11:12am |
