Home > Technical (L322) > Towbar Electrics 7 Pin |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Not sure if you can buy the plug that fits the boot socket on its own.
8th May 2023 3:08pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1190 |
I can confirm that the Gap IID can do the configuration you will have to tell which pin unit you have 13 or 7 pins which will disable the parking sensors and fog. 2017 SDV8 4.4 silicon silver AB
8th May 2023 5:22pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 820 |
thanks chaps, much appreciated ! |
9th May 2023 11:09am |
Steve RR Member Since: 28 Jan 2013 Location: Ayrshire Posts: 16 |
What about the trailer stability assist? Is this active or needs turned on too?
17th Jul 2023 9:44am |
