Home > Technical (L322) > Towbar Electrics 7 Pin
pcourtney
Need some help sorting out my towbar and 7 pin connector
I have a MY2011 car with the towbar electrical connector pre-wired and in the boot shown below
and another angle
but the external 7 pin plug I bought only has 7 wires and sadly the end that goes in the boot has had the connector cut off, so I'm trying to find the correct mating connector for it
also, does the IID Tool from GAP have the ability to register the trailer coupling and also activate the trailer functions:
• Rear fog lamp deactivation and • PDC deactivation
Post #663642 8th May 2023 2:27pm
rjff
Not sure if you can buy the plug that fits the boot socket on its own.
There are two alternatives available from PF Jones, a 7 and a 13 pin socket for the trailer with the boot plug fitted. you fit the tow bar socket wiring yourself. They are happy to talk over the phone about what you need.
https://www.pfjones.co.uk/land-rover-range...506pf.html
Fitting instructions
https://www.pfjones.co.uk/pfjoneswiringkit...ctrics.pdf
https://www.pfjones.co.uk/pfjoneswiringkit..._09-09.pdf
They may be available elsewhere.
Personally I would purchase the 13 pin unit and an adaptor for the 7S 7N .
I think the GAP can do the PDC and fog, but others may confirm, and IIRC mine when fitted was not coded but was plug and play.
HTH Cheers
Richard
Gap IIDBT
Post #663644 8th May 2023 3:08pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I can confirm that the Gap IID can do the configuration you will have to tell which pin unit you have 13 or 7 pins which will disable the parking sensors and fog. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #663657 8th May 2023 5:22pm
pcourtney
thanks chaps, much appreciated !
Post #663706 9th May 2023 11:09am
Steve RR
Scotland 2011 Range Rover Vogue SE TDV8 Fuji White
What about the trailer stability assist? Is this active or needs turned on too?
I did see something in the listing on the Gap site that is is only available with surround camera system, I can’t see that affecting the stability, perhaps the tow assist with the active reversing lines etc, I have that on the Disco 4 but only standard single camera on the L322, perhaps a wording mistake on their site? 2011 Disco 4
2011 TDV8 FFRR
4.6 P38 Autobiography x2
300Tdi county 110
Too many late Classic RR to count
Bowler Tomcat Smile
Post #669255 17th Jul 2023 9:44am
