Home > Maintenance & Mods (L322) > A few annoying "features" |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
On the 9MY> you can set door unlock on engine off in the CCF sir...
30th Apr 2023 9:47am |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 |
hmm is there anyway to also do it when the car is on? i mean that defo helps cause I tend to turn the car off, go open the boot and boom its locked.
30th Apr 2023 9:50am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 |
Disable drive-away locking in the CCF to stop the doors auto locking. If you then want them locked simply press the lock button that's below the hazzard switch. |
30th Apr 2023 11:32am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
If I park on a steep slope overnight facing up I get an oil pressure light for a few seconds on start-up. Never seen it on the flat apart from after draining a cold engine when all the oil has flowed into the sump. 2012 TDV8 Vogue (L322) |
30th Apr 2023 11:56am |
yeah I park on a slope facing downwards. Its actually a sport
30th Apr 2023 1:43pm |
