![]() | Home > Maintenance & Mods (L322) > A few annoying "features" |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
On the 9MY> you can set door unlock on engine off in the CCF sir...
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
hmm is there anyway to also do it when the car is on? i mean that defo helps cause I tend to turn the car off, go open the boot and boom its locked.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
Disable drive-away locking in the CCF to stop the doors auto locking. If you then want them locked simply press the lock button that's below the hazzard switch. |
If I park on a steep slope overnight facing up I get an oil pressure light for a few seconds on start-up. Never seen it on the flat apart from after draining a cold engine when all the oil has flowed into the sump. 2012 TDV8 Vogue (L322) |
yeah I park on a slope facing downwards. Its actually a sport |
