![]() | Home > Technical (L405) > EGT sensor/ EML on. |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1309 ![]() ![]() |
There is no pic
Tommybuk Member Since: 17 Jan 2024 Location: Ellon Posts: 13 ![]() ![]() ![]() |
Thanks Kot.
![]() Hopefully these pics I've uploaded will now show. 👍 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Seems to be my current issue, which happened while I’m away towing a tin tent…..
It could well be the egt sensor on the manifold on the left side. I changed 3 them on mine, as I remember, 2 on the exhaust, but the manifold one is the tricky one. There is threads on here detailing the process to change that one. |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 508 ![]() ![]() ![]() |
FYI, when Ecuador fault codes are cleared, the fault may still be there but the eml light doesn’t come on til 3 activations have been received again by the ecu. Mine is currently showing the eml for the exhaust gas sensor, when I’m home later in the week I’ll dig out the lr assist fault diagnosis, sensor wasn’t in stock when I took it in last week First time FFRR owner |
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
I had the same issue, I posted about it on forum. I would say it will be the sensor on n/s exhaust manifold. ( have read on my post , may help) it is a tinker to get out, access is tight. I would say lift bonnet to service position, it helps a lot. They can be very tight , my snapped and needed to replace exhaust manifold. |
Just as an FYI, I’ve just had mine replaced under warranty. The sheet from Landrover shows it as a 0.7hr job and £220 all in. As the genuine sensor is probably about £80 it’s it really worth the faffing about….. There is nothing that can't be fixed with a hammer😜😜
