Home > Technical (L405) > EGT sensor/ EML on.
Tommybuk
Scotland 2016 Range Rover Autobiography SDV8 Barolo Black
EGT sensor/ EML on.
Hi,
Can anyone shed some light on these fault codes attached?
2016 L405 4.4. EML is on. No faults or any issues running or driving.
Codes 2080-62 and 0546-17. Both suggest EGT sensor bank 1 sensor 1. I replaced the first sensor on the drivers side (uk car) (RHD).
I've circled it on the pic. The one after the oxygen sensor.
The codes and EML clear but then come back on after one or two starts.
Wondering whether anybody has had the same problem.
Thanks.
Post #683006 17th Jan 2024 3:29pm
Kot
There is no pic
If you have changed the correct sensor it could be the plug or harness problems.
The P2080-62 compares more than 1 sensor for mismatch at cold start so if one is short/open circuit/high resistance etc then this DTC activates this code number.
See these from WS manual
 2018 SE SDV8 4.4 Byron Blue
Post #683023 17th Jan 2024 6:01pm
Tommybuk
Thanks Kot.
Makes sense what you are saying, and I was planning trial and error on the other sensors.
Hopefully these pics I've uploaded will now show.
Post #683025 17th Jan 2024 6:22pm
Seems to be my current issue, which happened while I’m away towing a tin tent…..
Managed to get a garage to read and clear the codes, but looking at this it’s probably likely to pop up again when I start it up in the morning.
Hopefully it will make it home without a restricted performance error. Does anyone know how hard it is to swap out the EGT sensor and which one needs doing. Presumably the turbine temperature sensor, on the passenger side, I will have to dig out the WM and have a look back if I make it home!! There is nothing that can't be fixed with a hammer😜😜
Post #707057 16th Dec 2024 6:50pm
Tommybuk
It could well be the egt sensor on the manifold on the left side. I changed 3 them on mine, as I remember, 2 on the exhaust, but the manifold one is the tricky one. There is threads on here detailing the process to change that one.
Post #707069 16th Dec 2024 8:33pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
FYI, when Ecuador fault codes are cleared, the fault may still be there but the eml light doesn’t come on til 3 activations have been received again by the ecu. Mine is currently showing the eml for the exhaust gas sensor, when I’m home later in the week I’ll dig out the lr assist fault diagnosis, sensor wasn’t in stock when I took it in last week First time FFRR owner
Post #707074 16th Dec 2024 9:49pm
