![]() | Home > Technical (L322) > 2010 4.4 TDV8 - P2264-00 (2F) Water in fuel sensor circuit |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 841 ![]() ![]() ![]() |
GAP IID is coming up with "Water in fuel sensor fault code" , I clear the code but it comes back 2 or 3 days later, this contact inside the rubber plug breaking down over time makes sense though GaryRR Last edited by pcourtney on 18th Aug 2024 9:14am. Edited 3 times in total |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 ![]() ![]() ![]() |
For those that are struggling to find the genuine LR sensor harness which is no longer available separately to the fuel filter assembly - it is a Ford part. The part numbers are 6C119155BE
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 71 ![]() ![]() ![]() |
been getting this on and off for a couple of weeks and had been hunting all over for the replacement parts, much appreciated the heads up on it being a Ford part! 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
SoT RR Member Since: 30 May 2024 Location: Stockholm Posts: 2 ![]() ![]() ![]() |
Hi, I been having the same problem as you had with the "water in fuel sensor" and the RP varning. Did the problem reappere for you or did the change of the harnes and sensor cure it long term? BR //Ted |
Mfcetin Member Since: 26 Jun 2023 Location: Nürnberg Posts: 64 ![]() ![]() ![]() |
Replacing the harness worked for me. Done more than 3000km and not a single time came that RP warning. I replaced it with a new one from a fuel housing assy for a RR sport 2011 Vogue SE 4.4 TDV8 |
some have also had success with a smear of vaseline ( petroleum jelly ) applied to the connector circled in yellow
That's worth trying, thanks! |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 254 ![]() ![]() ![]() |
Thanks for the tip. I smeared Lanoguard grease on the connector two weeks ago, and no error code since. Coincidence? Time will tell. 2011MY 4.4TDV8 Autobiography Baltic Blue TVR Griffith Alfa Romeo Mito QV |
Excellent news RR2B |
[quote="RR2B"]
Over 4 months on and no further error codes. Success! 2011MY 4.4TDV8 Autobiography Baltic Blue TVR Griffith Alfa Romeo Mito QV |
fab news - well done that man |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Hi guys
fatu Member Since: 02 Feb 2024 Location: Prague Posts: 40 ![]() ![]() ![]() |
I still have this problem too, kind of learnt to live with it. It comes and goes at it pleases. It never goes off she it comes and car is on until it is off and parked for a while then it is just pure luck if it comes again or not. Never comes on while driving only when I start the car. Definitely water in fuel and definitely something to the with fuel priming with that damn sensor being broken or something. Lots of Vaseline or little bit Vaseline has been used in and around the sensor. Helps but still comes back annoyingly. Housing needs to be changed I think, but I will leave that to another fix I will combine with to do later. Range Rover 2012 4.4 TDV8 - current
