![]() | Home > Maintenance & Mods (L322) > Alignment / Tyre Wear |
JDRR Member Since: 04 Apr 2023 Location: Kent / Sussex Posts: 11 ![]() ![]() ![]() |
Hi All,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
Garage with Hunter system for four wheel alignment. Should be set in tight tolerance mode. Check with them that they do it.
Straightforward. Have to access the menu but IIRC through the suspension setup. John
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
Before you take action, as it is a front tyre and you only mention one side wearing, has the car had a new steering arm joint or any recent work on the front end? It could just be a simple case of the tracking being out, which can be rectified at most good garages. Just a thought, could save uou a few pennies |
Thanks Weegie,
You have PM John
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Thanks, I'll scroll through the menu. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1564 ![]() ![]() ![]() |
I went to Tyre Spot in Durham today and got a 4-wheel alignment check on my L405.
Wear on a single tyre would suggest more than a simple toe adjustment. Worn bushes, joints, shock absorbers etc should all be investigated. 2012 TDV8 Vogue (L322) |
