Home > Maintenance & Mods (L322) > Alignment / Tyre Wear |
JDRR Member Since: 04 Apr 2023 Location: Kent / Sussex Posts: 11 |
Hi All,
4th Apr 2023 1:38pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Garage with Hunter system for four wheel alignment. Should be set in tight tolerance mode. Check with them that they do it.
4th Apr 2023 2:01pm |
Straightforward. Have to access the menu but IIRC through the suspension setup. John
4th Apr 2023 2:07pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1180 |
Before you take action, as it is a front tyre and you only mention one side wearing, has the car had a new steering arm joint or any recent work on the front end? It could just be a simple case of the tracking being out, which can be rectified at most good garages. Just a thought, could save uou a few pennies |
4th Apr 2023 2:12pm |
Thanks Weegie,
4th Apr 2023 2:13pm |
You have PM John
4th Apr 2023 2:24pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Thanks, I'll scroll through the menu. |
4th Apr 2023 2:33pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1418 |
I went to Tyre Spot in Durham today and got a 4-wheel alignment check on my L405.
17th Jun 2023 2:56pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3188 |
Wear on a single tyre would suggest more than a simple toe adjustment. Worn bushes, joints, shock absorbers etc should all be investigated. 2012 TDV8 Vogue (L322) |
18th Jun 2023 8:04am |
