![]() | Home > Maintenance & Mods (L322) > drop the engine or work in situ ? |
We always used to drop the powertrain & front subframe as a unit from below the body, leaving the body on the two-poster, I suppose you could do it the other way but we had the benefit of the mandated 'special tool' so we'd never do it any other way.... |
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 31 ![]() ![]() ![]() |
You have me intrigued. Tell me more about this mandated special tool. Not come across this before. |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 ![]() ![]() ![]() |
If you have a 2 post why wouldn't you do it that way? Gives an opportunity to clean up the subframe and do any other necessary work that's hard to access with the powertrain in place. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
It's just a hydraulic platform with support arms and location pins to hold the subframe and power train in the correct orientation for removal & refit operations, probably similar to the assembly line tooling but adjustable. You could probably do similar with a few axle stands, wooden blocks and ratchet straps to support everything whilst you lift the body. Make sure you strap the body to the lift as the balance will change with the power train unbolted.... |
Thanks for that. It is going to be axle stands etc, so the tip about securing the body to the lift is very much appreciated. |
