Home > Maintenance & Mods (L322) > drop the engine or work in situ ?
B100
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
My TDV8 is using coolant and a head gasket leak has been confirmed. It did overheat badly beforehand, so a warped head is suspected. Whilst I am in that area, I plan to replace both turbos at 150k miles. I have a two-post lift. What is the recommended approach - to drop the engine and transmission complete on their subframes by supporting them at ground level and lifting the body off, or remove the heads and turbos in situ ? Advice from somebody who had done a body lift would be very much appreciated.
Post #660439 26th Mar 2023 9:54pm
Phoenix
We always used to drop the powertrain & front subframe as a unit from below the body, leaving the body on the two-poster, I suppose you could do it the other way but we had the benefit of the mandated 'special tool' so we'd never do it any other way....
Post #660442 26th Mar 2023 10:17pm
B100
You have me intrigued. Tell me more about this mandated special tool. Not come across this before.
Post #660457 27th Mar 2023 10:40am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
If you have a 2 post why wouldn't you do it that way? Gives an opportunity to clean up the subframe and do any other necessary work that's hard to access with the powertrain in place. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #660458 27th Mar 2023 10:43am
Phoenix
It's just a hydraulic platform with support arms and location pins to hold the subframe and power train in the correct orientation for removal & refit operations, probably similar to the assembly line tooling but adjustable. You could probably do similar with a few axle stands, wooden blocks and ratchet straps to support everything whilst you lift the body. Make sure you strap the body to the lift as the balance will change with the power train unbolted....
Post #660484 27th Mar 2023 3:21pm
B100
Thanks for that. It is going to be axle stands etc, so the tip about securing the body to the lift is very much appreciated.
Post #660614 28th Mar 2023 11:07pm
