![]() | Home > Technical (L405) > Ride quality -16 SDV8 AB |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 693 ![]() ![]() |
I had asked about that on here aljo but the only suggestion was a battery off reset.
So it's got another problem that's developed today.
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I’ve been keeping a keen eye on this thread hoping for you to find a fix to these issues…
I'm trying my best ffrr, looking an all angles and noted down everything I've done,/tried in a book but I don't know how long my patience will last.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Although part of me does not want to say this, first it was abandoning a trip abroad, now it's smaller things like not wanting to drive 30 minutes for a nice walk. I think it is time for you to change your car and enjoy life a bit more. Another FFRR or something else, keep you and the Boss happy. |
Yes Merchy your right I should sell it and as you quote enjoy my life a bit more.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7860 ![]() ![]() ![]() |
I know when my L322 changed it was like flicking a switch, nothing gradual. It was parked in my garage. Parked up fine, next day fairly hard as soon as I drove it. A new height sensor and some calibration made it manageable, as on the other thread. I did wonder about the air bag rubber getting harder with age, but that would have been gradual.
Funny how yours was like a switch being flicked mjdronfield.
Been out with the multimeter and checked the resistance of the solenoid in all 4 dampers.
Successfully updated the CHCM and CHCMB, there was a slight and I mean slight improvement but it was very similar to the improvement I experience when removing and re inserting the adaptive damping fuse so I don't expect it will last. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
What was the resistance of the solenoids? |
The meter read 3.4 ohms for each damper solenoid, less the test leads gives a result of 2.9 ohms which would include the wiring to the dampers themselves from the CHCM.
Okay, I've found another line of inquiry.
A resistance of 3.4 ohms would cause a current draw of nearly 4A at a constant 13V. According to my IIDtool my L322s draw about 1.5A which would mean less than 50% duty cycle if mine are 3.4 ohms. I'll check one of mine as soon as I get a chance. IIRC the WSM states 1.5A and around 6 ohms but I'll check.
