Home > General (L405) > Speed Warning |
MrWold Member Since: 26 Feb 2022 Location: West Sussex Posts: 135 |
My 2012 Sport did but it appears to have been either dropped for the L405 or never existed in the full fats. I miss it and the analogue clock. Chris
21st Mar 2023 4:12pm |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 382 |
It has a speed limiter - well the early ones do anyway. There is a switch by the cupholder that if pressed will allow you to use the cruise control feature as a speed limiter - it will allow you to accellerate to a given speed and no further. Current:
21st Mar 2023 5:45pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1421 |
I have a speed limiter in mine, 5.0 Supercharged |
21st Mar 2023 6:29pm |
I may have misunderstood the OP but I am referring to the speed that could be set so that a warning 'bong' sounds when it is exceeded. Nothing to do with speed limiting or the road speed limit. Chris 2014 FFRR 4.4 SDV8 Autobiography Barolo Black 2012 RRS SDV6 HSE Baltic Blue and before I saw the light: 2011 Suzuki Grand Vitara SZ5 1998 Ford Mondeo V6 Ghia X 1990 Citroen BX GTi 1973 Triumph GT6 |
21st Mar 2023 7:14pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1148 |
Yes as MrWold says a warning sound as the set speed is exceeded. overfinch modified |
21st Mar 2023 10:05pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 236 |
No bong or chime when exceeded. I use the ASL feature on the highway and in school zones. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
22nd Mar 2023 4:42pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1515 |
I had a “bong!” in my new Ford Ranger and it drove me nuts, so I switched it off! Seemed a good idea at first, but if you want to limit your speed, the quieter FFRR way is better IMHO! “If it ain’t broke, don’t fix it” -where’s the fun in that? |
22nd Mar 2023 5:06pm |
Ok thanks guys , no bong it is then. overfinch modified |
22nd Mar 2023 6:23pm |
Not quite sure why you need a bong? with the limiter engaged you can keep your foot flat to the floor and it wont exceed set limit so why would you need a bong? Have I missed something? |
30th Mar 2023 8:47am |
I have just reread, I assume the original question is, as the car identifies the speed limit of the road on which you are travelling, does the car warn if you exceed the actual speed limit, short answer is no, but if you have waze then you can set that to warn if you exceed the speed limit of the road you are on. |
30th Mar 2023 8:49am |
Again, nothing to do with speed limits or the ASL.
30th Mar 2023 11:15am |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 |
Actually it will, but only if you have traffic sign recognition, from the owner's manual: [/quote] |
30th Mar 2023 9:06pm |
Hi fifth Horseman mine does have trafic sign recongnition so i can look to switch this on it tells me on my HUD the roads speed limit now but no warning if its exceeded. thx. overfinch modified |
30th Mar 2023 9:14pm |
There should be an option in the TSR menu for speed alerts, it is possible however that it is not enabled in the CCF.
31st Mar 2023 7:08am |
