Home > General (L405) > Speed Warning
caymanblack
Speed Warning
Does the L405 have a speed limit warning bong? My wife's Yeti has this and is useful on mine all I can see is the speed limit for the road I'm on but no warning if I exceed it. thx. overfinch modified
Post #659976 21st Mar 2023 4:44pm
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
My 2012 Sport did but it appears to have been either dropped for the L405 or never existed in the full fats. I miss it and the analogue clock. Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #659977 21st Mar 2023 5:12pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
It has a speed limiter - well the early ones do anyway. There is a switch by the cupholder that if pressed will allow you to use the cruise control feature as a speed limiter - it will allow you to accellerate to a given speed and no further. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #659981 21st Mar 2023 6:45pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I have a speed limiter in mine, 5.0 Supercharged
Post #659986 21st Mar 2023 7:29pm
MrWold
I may have misunderstood the OP but I am referring to the speed that could be set so that a warning 'bong' sounds when it is exceeded. Nothing to do with speed limiting or the road speed limit. Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #659989 21st Mar 2023 8:14pm
caymanblack
Yes as MrWold says a warning sound as the set speed is exceeded. overfinch modified
Post #660002 21st Mar 2023 11:05pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
No bong or chime when exceeded. I use the ASL feature on the highway and in school zones. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #660046 22nd Mar 2023 5:42pm
Gremlin500
I had a “bong!” in my new Ford Ranger and it drove me nuts, so I switched it off! Seemed a good idea at first, but if you want to limit your speed, the quieter FFRR way is better IMHO! Thumbs Up â€śIf it ain’t broke, don’t fix it” -where’s the fun in that?
Post #660049 22nd Mar 2023 6:06pm
caymanblack
Ok thanks guys , no bong it is then. Laughing overfinch modified
Post #660056 22nd Mar 2023 7:23pm
DrF
Not quite sure why you need a bong? with the limiter engaged you can keep your foot flat to the floor and it wont exceed set limit so why would you need a bong? Have I missed something?
Post #660688 30th Mar 2023 9:47am
DrF
I have just reread, I assume the original question is, as the car identifies the speed limit of the road on which you are travelling, does the car warn if you exceed the actual speed limit, short answer is no, but if you have waze then you can set that to warn if you exceed the speed limit of the road you are on.
Post #660689 30th Mar 2023 9:49am
MrWold
Again, nothing to do with speed limits or the ASL.
It might never have been available on the L405 but my 2012 Sport had a 'bong' that could be set to any speed. It may have been available in the L322 but I don't know. I think it was in the 'vehicle set up' menu so not something that you would change frequently. I had it set to 73 to warn me that my speed was creeping up without me realising, as it tends to in these cars while you waft along.
I found it very useful and have never used my ASL. Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #660695 30th Mar 2023 12:15pm
Fifth Horseman
Actually it will, but only if you have traffic sign recognition, from the owner's manual:
Quote:
The three basic functions of the traffic sign recognition system are as follows:
Speed limit detection: The instrument panel displays a corresponding sign.
Speed alert: When the vehicle's speed is greater than the detected speed limit, a warning is displayed. The instrument panel displays a flashing red ring around the detected speed limit sign. Speed alert can be switched on or off, or the settings can be adjusted to display three different settings:
When the vehicle's speed equals the detected speed limit.
When the vehicle's speed is 10 km/h (5 mph) above the detected speed limit.
When the vehicle's speed is 20 km/h (10 mph) above the detected speed limit.
[/quote]
Post #660724 30th Mar 2023 10:06pm
caymanblack
Hi fifth Horseman mine does have trafic sign recongnition so i can look to switch this on it tells me on my HUD the roads speed limit now but no warning if its exceeded. thx. overfinch modified
Post #660725 30th Mar 2023 10:14pm
Fifth Horseman
There should be an option in the TSR menu for speed alerts, it is possible however that it is not enabled in the CCF.
IIRC even when enabled the overspeed alerts only show in the instrument panel and not the HUD.
Post #660735 31st Mar 2023 8:08am
