Home > Maintenance & Mods (L322) > 3.6 TDV8. An endless search for the correct oil
Whereisrover
Quote:
The workshop manual shows 934 as recommended for 3.6 when fitted with DPF, so the engine itself is clearly able to use that same spec whether or not DPF-equipped.
I've snipped this from an image posted on this site of an owner's handbook. It's not showing 934 spec for the 3.6, could this have been updated on the workshop manual since then?
If so then it solves a huge part of the headache I've had trying to get the correct oil spec as few places seem to hold anything that lines up with 921-A
Post #659429 15th Mar 2023 9:05am
Danb_220_2019
United Kingdom 2012 Range Rover Vogue SE TDV8 Fuji White
My post, number 3 in this thread, is a screenshot of the workshop manual oil specifications from the WSM in the Wiki, and shows 934. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica.
Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500
Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten!
Post #659430 15th Mar 2023 9:13am
albertocsm
Portugal 2011 Range Rover Vogue 4.4 V8 Zambezi Silver
Would there be any real benefit in using a DPF-approved oil (e.g., Castrol EDGE 5W-30 C1) over a non-DPF oil (e.g., Castrol Magnatec Stop-Start 5W-30 A5) in a car that is not equipped with a DPF?
PS:
I own a 2011 4.4L TDV8, and it either came out of the factory without one (from what I've read, it's not completely impossible) or it was removed along the way. I'm not sure.
Post #659635 17th Mar 2023 12:10pm
GraemeS
Some or possibly all ROW 4.4 L322s weren't fitted with a DPF. The DPF compatible oils are a compromise so I won't use them, preferring to stick with non-DPF oil.
Post #659674 17th Mar 2023 8:05pm
