Home > Maintenance & Mods (L322) > 3.6 TDV8. An endless search for the correct oil |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 |
We use Comma Ecolife
14th Mar 2023 12:53pm |
Danb_220_2019 Member Since: 02 Jan 2023 Location: Suffolk Posts: 262 |
From the workshop manual:
14th Mar 2023 12:57pm |
Whereisrover Member Since: 14 Mar 2023 Location: UK Posts: 4 |
Thanks for the replies. Needed to hear from some people that had actually used different oil to put my mind at rest.
14th Mar 2023 1:14pm |
I run all my vehicles on a 6K or 12m schedule whichever comes first for engine oil.
14th Mar 2023 1:43pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
*highly advised* by most RR owners to change oil every 5,000 miles, at least every 12 months.
14th Mar 2023 5:10pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2554 |
A1 has been superseded by A5.
14th Mar 2023 8:00pm |
Rudyard1 Member Since: 15 Nov 2021 Location: Leicestershire Posts: 81 |
I am looking at changing oil soon and think I will use the following:
14th Mar 2023 8:21pm |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 281 |
20% off with Opie at the moment; https://www.opieoils.co.uk/t-Current-Offer.aspx TDV8 4.4 2012 |
14th Mar 2023 8:28pm |
I had exactly that issue. Please post if you find supplier of 5 Ltr TDV8 4.4 2012 |
14th Mar 2023 8:32pm |
Looking at the suggestions in replies a lot seem to line up with the oil specification for the 4.4 TDV8, is the specification for the 3.6 TDV8 now considered the same?
15th Mar 2023 7:39am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
The 4.4 has a DPF and requires low SAPS (Low ash) spec oil. I can't see an issue running this in a 3.6 if this is all you can find in the right quantity. 2012 TDV8 Vogue (L322) |
15th Mar 2023 7:45am |
Yes, apologies; I was implying the 4.4 TDV8 spec in my reply above. Hope that’s not confused too much; your post caught my interest as I really struggled to find the low ash spec required for the DPF mentioned by @JayGee. As I only needed a top up I ended up buying a 1ltr Castrol Edge Professional C1 from Amazon. The car’s due a full change after Easter and, following this thread discussion, I think I’m going with Opie or Smith & Allan rather than a main stream brand. Perhaps it might be worth giving either of these suppliers a call to see what they say. TDV8 4.4 2012 |
15th Mar 2023 8:00am |
The correct spec for the 4.4 is labelled 'C1' and easily ordered through either Opie or S&A via their online ordering process. 2012 TDV8 Vogue (L322) |
15th Mar 2023 8:19am |
The workshop manual shows 934 as recommended for 3.6 when fitted with DPF, so the engine itself is clearly able to use that same spec whether or not DPF-equipped. 2012 (L322) 4.4TDV8 Vogue SE, RSE, Fuji White over Arabica. Previous V8s: BMW 645Ci, P38 4.6, P38 4.0, Merc CL500 Previous others: Honda x1, Volvo x7, Rover x6, BMW x6, Ford x1, Mercedes x2, Skoda x3, VW x2, Renault x2, Citroen x1, Mazda x3, Nissan x1, Audi x3, Kia x1, Fiat x4, Subaru x3, Austin x2, Triumph x2, Jeep x2, Hyundai x2, Lexus x1, Mitsubishi x1, Saab x2... and some others I've forgotten! |
15th Mar 2023 8:49am |
