Home > Technical (L322) > Crackling (?) noise from windshield corners?
vektory
Austria 2012 Range Rover Vogue TDV8 Sumatra Black
Hello everybody!
Yesterday I recognized a crackling (sizzling) noise, coming mainly from the passenger corner at the windshield and only when driving faster than 100 km/h (60 mph). It is hard to describe it, but it sounds like a dry leaf is fluttering or the sound plastic makes when getting crumpled...not very loud but recognizable. Mainly from the passenger side (left), but sometimes also a little bit in the driver's side...always in the corners. Suspecting that it is coming from the inside...
I did a quick inspection under the hood but nothing obvious popped up. May be some foreign matter in the HVAC system at the filter? Noise gets then transported through the vents into the cabin? Could it be a noise from the speakers? Noise is only there when driving on the speedway, so I do not think that this related to the sound system but what do I know
Any hints are very much appreciated. Having my RR now for one week and start to recognize some things.
Thank you!
p.s.: It's a 4.4 TDV8 MY 2012
Post #658433 4th Mar 2023 12:23pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
I have the same. I thought it may be a loose screw in the airbag area of the A pillar but all was good there. I think it is the external A pilar trim. The clips are notorious for breaking expeeically after a screen replacement. Could be that? They are c. £20.
Post #658439 4th Mar 2023 1:20pm
vektory
Very good hints!
Will order the clips and give it a try on the A pillar external trims:)
Checking the airbag trims will not break the respective airbag pillar clips, will it? TDV8 4.4 MY2012 Vogue Trim
Post #658444 4th Mar 2023 1:48pm
Dolphinboy
no, there is a 'how to' in the post somewhere. search "Pillar".
Post #658450 4th Mar 2023 3:21pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Mine does something similar to this too but only on really cold mornings. I had just put it down to plastic components in the dashboard corners expanding as they warmed up as the heating kicked in but will be interested to see if you guys come up with another cause for it. 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #658457 4th Mar 2023 5:04pm
Dolphinboy
just been outside and checked my exterior black plastic trims.............. hey ho, not fully pressed home on leading edge. Simple palm push along the whole length and all good. No more noise!!
Post #658546 5th Mar 2023 4:57pm
vektory
Was also checking the plastic trim now....had to find out there is a little gap to the windshield. Could not push it in, so will order some new clips and install them Smile
This should be the root cause for the noise. Will keep you posted. TDV8 4.4 MY2012 Vogue Trim
Post #658572 5th Mar 2023 7:29pm
vektory
Short update:
I mounted new clips and now the noise is not completely gone, but the situation is much better. Really seems to be the root cause for this Smile
Might need to buy new trims to completely get rid of this noise. TDV8 4.4 MY2012 Vogue Trim
Post #660475 27th Mar 2023 12:49pm
kevinp
I found the original clips didn't hold the trim tight.
I found some slightly shorter ones and had to bash the trim quite hard to seat them resulting in no noise.
Post #660491 27th Mar 2023 3:40pm
vektory
You don't happen to remember which clips you did buy, do you?
Maybe the ones from allbrit? TDV8 4.4 MY2012 Vogue Trim
Post #660493 27th Mar 2023 3:52pm
kevinp
I'll have a look for you in a bit.
Post #660502 27th Mar 2023 5:14pm
Dolphinboy
check the inner part of the trim where it fits onto the windscreen (ie. nothing to do with the clips/pins on the door frame.) I found that the whole length had come away from the windscreen and needed glueing back down.
Post #660506 27th Mar 2023 5:38pm
vektory
It is true that the whole length is not completely tight to the windscreen. You did not glue the rubberlip to the windscreen, did you? The lip is still nice sitting on the plastic trim
Kevinp's proposal sounds good to me, as slightly shorter/smaller pins may enable a tighter seat in the A pillar, resulting in a good fit towards the windscreen. No?
Besides that the problems are increasing lately with a supposedly half broken air compressor now...sigh... TDV8 4.4 MY2012 Vogue Trim
Post #660562 28th Mar 2023 9:04am
kevinp
Hi Vektory, I've just been and had a look, but I've got dozens of clips and can't remember which ones I used!!
All I can tell you is they are only about 1mm shorter than the originals and have a barbed end rather than the looped design of the originals so they actually 'click' into place.
Sorry I can't help you more.
Post #660572 28th Mar 2023 12:52pm
