Home > Technical (L322) > Crackling (?) noise from windshield corners? |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3143 |
I have the same. I thought it may be a loose screw in the airbag area of the A pillar but all was good there. I think it is the external A pilar trim. The clips are notorious for breaking expeeically after a screen replacement. Could be that? They are c. £20. |
4th Mar 2023 1:20pm |
vektory Member Since: 27 Feb 2023 Location: Vienna Posts: 21 |
Very good hints!
4th Mar 2023 1:48pm |
no, there is a 'how to' in the post somewhere. search "Pillar". |
4th Mar 2023 3:21pm |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 84 |
Mine does something similar to this too but only on really cold mornings. I had just put it down to plastic components in the dashboard corners expanding as they warmed up as the heating kicked in but will be interested to see if you guys come up with another cause for it. 2012 Westminster TDV8 4.4 Indus Silver
4th Mar 2023 5:04pm |
just been outside and checked my exterior black plastic trims.............. hey ho, not fully pressed home on leading edge. Simple palm push along the whole length and all good. No more noise!! |
5th Mar 2023 4:57pm |
Was also checking the plastic trim now....had to find out there is a little gap to the windshield. Could not push it in, so will order some new clips and install them
5th Mar 2023 7:29pm |
Short update:
27th Mar 2023 12:49pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1206 |
I found the original clips didn't hold the trim tight.
27th Mar 2023 3:40pm |
You don't happen to remember which clips you did buy, do you?
27th Mar 2023 3:52pm |
I'll have a look for you in a bit. |
27th Mar 2023 5:14pm |
check the inner part of the trim where it fits onto the windscreen (ie. nothing to do with the clips/pins on the door frame.) I found that the whole length had come away from the windscreen and needed glueing back down. |
27th Mar 2023 5:38pm |
It is true that the whole length is not completely tight to the windscreen. You did not glue the rubberlip to the windscreen, did you? The lip is still nice sitting on the plastic trim
28th Mar 2023 9:04am |
Hi Vektory, I've just been and had a look, but I've got dozens of clips and can't remember which ones I used!!
28th Mar 2023 12:52pm |
